is my UG802 dead ?
mite_jan
is my UG802 dead ?
Postby mite_jan » Sun Jan 27, 2013 6:20 pm
HI
at first when i have started the UG802 i have noticed a blue led which probably mean that the stick is powered on
tried reseting the power couple of times and now i am not even seeing the blue led and i am seeing no signal input on the monitor ... any ideas what i can try ?
when i connect the stick to the PC (without connecting the 2 pins inside it) i get a message " usb device not recognised , one of the usb devices attached to this computer has malfunctioned, and windows cannot recognise it "
does this means it is faulty ?
here is the picture of the 2 pins (4 pins in my device ?!?!)
is there a way i can revive it
flowd
Re: is my UG802 dead ?
Postby flowd » Sun Feb 17, 2013 6:36 pm
Hm.. Somehow I can not see your Image now, but i barely remember you opened your Stick, right?
I heard somewhere that the USB connector of some UG802 versions is soldered with less quality and the joint can brake. Look very close, maybe that happened to your device. Maybe you can test if one joint is dead or so, and very carefully you can resold it.
I hope you understand my bad english^^
Return to “UG802”
