UG802 Specifications
Postby deadhp1 » Sat Sep 22, 2012 11:09 am
The UG802 specifications are as follows:
Dual Core RK3066 SOC running at 1.2Ghz
1GB of ram
4GB of NAND storage
Wifi b/g/n RTL8188EUS
Micro SD card slot
Micro USB for power
Full size USB Host
HDMI 1.4 male port
There are 2 models to date with different Wifi antenna. One antenna is a hard pcb board soldered with a cable. The other antenna is a flexible foil type antenna.
Perepandel
Re: UG802 Specifications
Postby Perepandel » Mon Oct 22, 2012 6:15 pm
My antenna seems to me a mix between the two. It looks like the "flexible foil" one, but its not like the orange/brownish ones pictured in this forum. It's soldered to the board with a thin cable, but it's not made of PCB. It's, solid like a paperclip but flat, and there is the adhesive foil, which looks like metallic paper, used to attach it to the case.
In fact, I took a picture of it:
Return to “UG802”
