Tronsmart MK908 images, specs and demo video of UI
Castaa
Postby Castaa » Fri Apr 19, 2013 5:27 pm
Specification for Tronsmart MK908:
CPU: RK3188 Quad Core 1.6GHz (Cortex-A9)
Ram: DDR3 2GB
Rom On board NAND Flash 4G/ 8G/ 16G
Micro SD Card/ T-Flash (Maximum support 32GB)
Video Format MPEG-1/ MPEG-2/ MPEG-4/ H.264/ AVS/ VC-1/ RV8/ RV9/ RV10 / VP6/ VP8 / Sorenson Spark/ MVC 1080p@60fps (1920×1080) ; H.263 576p@60fps(720×576)
Audio Format Support: MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV
Picture Format Support: Max.8000×8000 JPEG BMP GIF PNG
WIFI Broadcom AP6210, Support 802.11 b/g/n,Bluetooth 4.0
Output MINI HDMI Port
Ports:
1-Mini USB, Support OTG
1-Standard USB
1-Mini USB for power
1-TF card slot
1-LED power indicator
1-Physical button(For upgrading software)
OS: Google Android 4.1 (uprade to Android 4.2 coming: April 30th)
Dimensions: 88mm * 31.5mm * 15.8mm
Weight: <50g
Working environment: 5°C–35°C,30%–90% Humidity
Storage environment: -20°C–60°C,10%–90% Humidity
Video of Tronsmart MK908 in action: http://www.youtube.com/watch?v=KjCV2B82-BM
Castaa
Re: Tronsmart MK908 images, specs and demo video of UI
Postby Castaa » Fri Apr 19, 2013 5:30 pm
Not sure it running the quad core CPU running at 1.1 Ghz is going to make it feel faster. Maybe the MK808 is still a better deal. Opinions?
Postby geekbuying » Fri Apr 19, 2013 9:30 pm
HI
Where did you seee the CPU is only 1.1 Ghz? it is WRONG! The cpu is in 1.6Ghz, and quad core.
Castaa
Postby Castaa » Sat Apr 20, 2013 3:40 am
Ok updated it to 1.6 GHz
KPap13
Postby KPap13 » Sat Apr 20, 2013 5:54 am
No Antutu why is very slow?
And inside images? Ok its cheap solution but except wifi have cut and other hardware?
Postby deadhp1 » Sat Apr 20, 2013 5:06 pm
I've ordered one of these and will be reviewing it.
I'm going to run a full set of benchmarks on it as soon as it comes.
genny
Postby genny » Sun Apr 28, 2013 4:45 am
A good video review about MK908
http://www.youtube.com/watch?v=8j5ZFlJB7eo
Nex00x1
Postby Nex00x1 » Sun May 05, 2013 5:50 pm
geekbuying wrote:HI
Hi.
What is the best free tool to see CPU's speed in MK908?
Nex00x1
Postby Nex00x1 » Tue May 07, 2013 2:30 pm
geekbuying wrote:I use Antutu.
I've tried it and it is a very good tool free. CPU freq is 1608 Mhz (x4).
Thank you :)
Return to “Tronsmart MK908”
