RK3066 Kernel question
qianzhi1
Postby qianzhi1 » Mon Oct 26, 2015 6:53 pm
I have two identical RK3066 Chinese “Wobo Q5” TVboxes (http://www.Wobo.tv) . One of them was stuck in the update loop while I tried to update the firmware using a wrong file. Since then, I was able to resurrect it by copying all the related images (i.e., parameter, boot.img, kernel.img, misc.img, recovery.img, system.img) from the "good" unit. Now it works with the AV output, but the HDMI and USB do not work when OS is up. Even though the USB OTG works. I was under the impression that the Kernel should work the same for both, isn't that correct? any recommendations?
Return to “Rockchip RK3066”
