Ubuntu Linux for RK3066 devices (pre-Alpha 0.3 released)
AndrewDB
Re: Ubuntu Linux for RK3066 devices
Postby AndrewDB » Thu Nov 29, 2012 12:31 pm
aloksinha2001 wrote:Andrew,
Some glitches found... where to report... here or on the github?
Alok
Here it's fine!
bluepeter
Postby bluepeter » Thu Nov 29, 2012 3:25 pm
Waiting for my stick to arrive is killing me, I wanna join in the fun :cry:
regards
Peter
AndrewDB
Postby AndrewDB » Thu Nov 29, 2012 7:40 pm
Pre-Alpha 0.2 is out, can now boot from any mass storage device recognized at boot time (e.g. USB key, USB card reader, internal microSD card slot, etc).
kriss_fr
Re: Ubuntu Linux for RK3066 devices (pre-Alpha 0.2 released)
Postby kriss_fr » Fri Nov 30, 2012 3:00 am
Hi all,
For guys who wants to boot always on ubuntu i have a (quick an dirty) solution. It check if your sdcard is plug in the slot at android boot. if it is, it's reboot recovery, else it stay in android OS.
write a script (i call it ubuntu_boot.sh) :
if [ -a "/dev/block/vold/179:1" ]
  then
        reboot recovery
fi
With smanager android app, choose this script to run at boot and with su permission.
If it don't work, please check your device id in an android terminal with the "mount" command (you should have plug your sdcard in the slot before) and look at the line whith "external_sd". if the device id is not "/dev/block/vold/179:1", so replace the value with your in the script.
AndrewDB
Postby AndrewDB » Fri Nov 30, 2012 4:08 am
kriss_fr wrote:Hi all,
  then
        reboot recovery
fi
Thank you kriss_fr,
This is excellent! well done!
agiler
Postby agiler » Fri Nov 30, 2012 7:03 am
Awesome!
this script is what I need on my imito mx1 :)
Waiting for pre-alpha 0.3 :lol:
kriss_fr
Postby kriss_fr » Fri Nov 30, 2012 9:24 am
AndrewDB wrote:Thank you kriss_fr,
thank you :)
Maybe you can share this tips in the first post and in the slatedroid topic ?
I think it can be usefull for many people.
deepego
Postby deepego » Fri Nov 30, 2012 3:51 pm
The links to download recovery+ubuntu in slatedroid not working.
any mirrors to download it?
antieco
Postby antieco » Fri Nov 30, 2012 4:20 pm
Does it works on MK808¿?
aloksinha2001
Postby aloksinha2001 » Fri Nov 30, 2012 4:55 pm
antieco wrote:Does it works on MK808¿?
Yes it does....
joshuahandrich
Postby joshuahandrich » Sat Dec 01, 2012 9:43 am
Is there any way to flash the root file system of Ubuntu to the system partition of the nand flash?
I would like to flash the Linux kernel to the boot partition (which I already know how to do) such that it will automatically boot into Ubuntu from internal memory.
Thanks,
Joshua
AndrewDB
Postby AndrewDB » Sat Dec 01, 2012 12:59 pm
joshuahandrich wrote:Is there any way to flash the root file system of Ubuntu to the system partition of the nand flash?
Thanks,
Joshua
That option will be available in a later release, at this pre-Alpha stage we are just testing the kernel and the root filesystem so it's better to have them on removable storage i.e. a microSD card or a USB key.
joshuahandrich
Postby joshuahandrich » Sun Dec 02, 2012 1:51 pm
Thanks for the information. I look forward to seeing your progress.
agiler
Postby agiler » Mon Dec 03, 2012 7:01 am
Any news about imito mx1 kernel?
Thanks for your work, Andrew
AndrewDB
Postby AndrewDB » Mon Dec 03, 2012 8:26 am
agiler wrote:Any news about imito mx1 kernel?
Hi agiler,
In fact the pre-Alpha 0.2 kernel should work on the iMito MX1, I just haven't had the time to test it on my UG007 (which is identical to the iMito MX1 internally).
I'll be releasing pre-Alpha 0.3 later today or tomorrow after testing it on the UG007, you may want to wait for that release.
agiler
Postby agiler » Mon Dec 03, 2012 8:57 am
Thank you!
I'm a completly noob on ubuntu running on arm devices.
Can I install sabnzbd and transmission without any problems? is there a different package source?
AndrewDB
Postby AndrewDB » Mon Dec 03, 2012 9:27 am
agiler wrote:Thank you!
It should be as simple as:
sudo apt-get install sabnzbd transmission
llewelld
Postby llewelld » Mon Dec 03, 2012 3:31 pm
can anyone tell me is graphics hardware acceleration working in the OS..
If something like xbmc is installed, will it have hardware acceleration?
aloksinha2001
Postby aloksinha2001 » Mon Dec 03, 2012 4:27 pm
llewelld wrote:can anyone tell me is graphics hardware acceleration working in the OS..
Not yet...
Alok
aloksinha2001
Postby aloksinha2001 » Mon Dec 03, 2012 6:09 pm
Transmission comes pre-installed... anything else u can just apt-get install <pkgname>
ALok
Return to “Rockchip RK3066”
