ACI for RK3066 (Autoinstall preconfigured XBMC)
Postby lewy20041 » Fri Mar 08, 2013 5:55 am
Additional Content Installer Auto installs and configure XBMC,
MX Player and DTS codec for use With HD/SD videos.
It adds TVLauncer, Onlive and other additional apps.
changelog:
V1.3
-automount cifs shares on boot (edit install-recovery.shxtv/install-recovery.shfw
to mach your server settings)
-new skin for xbmc
-and more...;)
V1.2
-XBMCHW [if you want to use test hw accelerated default player press "c" with keyboard on a movie you want to wach,
by default its set to use externall (MX Player)]
-keyboard.xml (backspace on keyboard act as back button in xbmc)
-repository superrepo (largest datbase of addons for xbmc)
-playercorefactory.xml (for use with externall player in xbmc)
-advancedsettings.xml (for better user experience in xbmc)
-guisettings.xml (preconfigured settings in xbmc)
-Additional Content Installer code cleanup
-insmod at startup mcs7830.ko (Usb->ethernet module)
-insmod at startup rtl8192cu.ko (wi-fi dongle module)
-insmod at startup rt5370sta.ko (wi-fi dongle module)
-insmod at startup xpad.ko (xbox360 controller module)
-Rebooter (Nice shoutdown/reboot app)
-MX Player 05.03.2013 (preconfigured with DTS)
-MX Player DTS Codec Pack
-TVLauncher
-Onlive
-Youtube for GTV
-cifs manager (mount yours shares as they are internall hdd)
-es explorer (manage your files with best file manager, auto apk install)
-hidebar 1.10 (hides status bar at startup)
-wallbase app (tons of great wallpapers)
-youtube for gtv
-persist.sys.scalerate (sets screan scale to 100%, so no need to change it
manualy aftrer fresh firmware install)
install:
-open "Aditional Content Installer" folder and install MoboroboSetup.exe
-connect your device with pc using otg port
-on device go to settings->Usb and check Connect to PC
-if you will be asked for drivers point to RockusbDriver in "Aditional Content Installer" folder
-run "ACI by lewy20041.exe"
-hit enter and wait
-after your device will reboot you are good to go
-if some app ask for permisions select "grant"
-if you want to unhide status bar at startup go to Hide Bar app and uncheck auto hide bar at startup,
you can unhide the bar useing mouse (just grab the battom of the screean and slide it up
Please post what you find out (bugs, what you like, what you dont like, etc.)
If any one wants to help me you can donate i will be wery greatefull.
Cheers!
Download:
http://adf.ly/KfnNj
MrFX
Re: ACI for RK3066 (Autoinstall preconfigured XBMC)
Postby MrFX » Fri Mar 08, 2013 9:47 am
seems to be the old version of TVLauncher?
The new one does not have the weather option...
Best regards,
MrFX
Postby lewy20041 » Fri Mar 08, 2013 11:05 am
yap. but new one is only to buy.
free is usless:"
joseacevedo
Postby joseacevedo » Tue Apr 02, 2013 11:13 pm
Thanks so much for this works very nice in my mx1.
Waiting for new updates.
Jose
Return to “Rockchip RK3066”
