How to make a new Android build for RK3066 devices?
Boeboe
Postby Boeboe » Tue Feb 26, 2013 1:07 pm
Hi all,
I have a MK809 and just finished compiling the kernel for it as described in the following post (http://www.armtvtech.com/armtvtechforum/viewtopic.php?f=4&t=1673).
Now I would like to make a new Android build as described on http://source.android.com/source/building-devices.html. Do I need some device (MK809) specific binaries/sources in my Android source tree?
Anyone has experience making there own Android build? I am targetting for the latest (JDQ39) android-4.2.2_r1 version.
BR,
Bart
Boeboe
Re: How to make a new Android build for RK3066 devices?
Postby Boeboe » Fri Mar 01, 2013 4:32 pm
In the meanwhile I found a very usefull post on this topic that put me in the right direction:
http://forum.xda-developers.com/showthread.php?t=1908008
metal
Postby metal » Thu Mar 07, 2013 6:30 am
Hi Boeboe
Any progress in building Android?
Boeboe
Postby Boeboe » Sun Mar 17, 2013 5:33 pm
Hi metal,
In the meanwhile I succesfully compiled the latest 4.2.2_r1 release with a 32 bit cross compilation toolchain for ARM. The result is an emulator which works well. I have posted my findings in a small document for others reference, since it is not all that obvious to compile a Jelly Bean release on a Ubuntu 12.04 32 bit OS. ( https://docs.google.com/file/d/0B669SSkGapIhbFpZR0lDNGx4VTQ/edit?usp=sharing )
I did not get the time yet to succesufully merge this with my original dongle firmware. Keep you updated when I did so.
metal
Postby metal » Fri Mar 22, 2013 8:39 am
Hi again, Boeboe
Thanks for the reply. Quite an impressive work, you have done in documenting building Android...well done.
I built Android using a 64 bit version of Ubuntu. My next step is to build a patched kernel, and try to run a vanilla build on my MK808B.
Users browsing this forum: No registered users and 4 guests
