Problem with USB-->LAN adapter
demokedes
Postby demokedes » Sat Feb 09, 2013 3:59 pm
I have mk808. I have two USB-->LAN adapters (USB 2.0). I tried with both. With first one: It is connected to my mk808 through US HUB (with external power supply). After reboot device doesn't receive IP address from DHCP automatically. I have to disable/enable LAN and then I get IP address. But the main problem is after few minutes/seconds. MK808 freezes. I have to reset it, if I want to use it. It is happening all thi time. When i Unplug dongle, problems dissapear.
With the second one, when I plug it, nothing happend. USB is recognized, but nothing happened.
What can I do? I can use wifi, but is not fast enough.
Thanks for any idea.
Regards
Craxx
Re: AW: Problem with USB-->LAN adapter
Postby Craxx » Sun Feb 10, 2013 5:24 am
I had same problem.... Try another adapter works for me ;-)
best regards
Craxx :-)
Send from my Nexus 4 with Tapatalk 2 :-D
demokedes
Re: Problem with USB-->LAN adapter
Postby demokedes » Mon Feb 11, 2013 11:32 am
I already have two adapters. Both have different problems. I don't want just random buying, because I don't know what the results will be?
ilearner3
Postby ilearner3 » Fri Feb 15, 2013 5:55 am
All these RK3066
should work with a USB2.0 to LAN(10/100M) adapter with AX88772_ chips.
May work with a USB2.0 to LAN(10/100/1000M) adapter with AX88178 chips
svadu
Postby svadu » Sat Mar 09, 2013 6:01 pm
ilearner3 wrote:All these RK3066
Doesn't work with AX88178. I have Sitecom LN-031 (AX88178) and it doesn't work.
ilearner3
Postby ilearner3 » Sun Mar 10, 2013 2:54 am
http://linux.m2osw.com/asix-electronics-ax88178-driver
https://github.com/AndrewDB/rk3066-kern ... usb/asix.c
Users browsing this forum: Bing [Bot] and 1 guest
