Can I flash any MK808 kernel on an Imito MX1?
mrblack1134
Postby mrblack1134 » Wed Jan 30, 2013 1:04 pm
I would assume that in that case only the bluetooth + wifi wouldn't be working?
I have an usb ethernet adapter so that would solve the connectivity problem. As for bluetooth I can always have a small usb dongle too.
Should I just use the standard rkflashtool procedure that I used to flash Finless's Imito 1.5 ROM? (ie. boot in usb mass storage mode, reset in flash mode, then flash)
Just wondering if it's all doable.
Btw, reason I want to do this is I suspect my Logitech C310 Webcam works better in the MK808 kernels than in the Imito kernels (only works for a few seconds on the Imito than dies).
Cheers
Thanks!
salundy
Re: Can I flash any MK808 kernel on an Imito MX1?
Postby salundy » Fri Feb 01, 2013 4:04 pm
I had it tested with the kisz kernel for the MK808 on my UG007, but it won´t start anymore.
Re-flashed the MX1 kernel from the finless Bob rom 1.5 (for the mx1) and the stick started again-
Even you get started the MK808 kernel on the UG007 or MX1, you wil not be able to use Wlan and BT. There are different chips installed and the kernel doesn´t contain the correct drivers.
