New devices with RK3066 and AML8726-MX chipsets
mrspin
Re: New devices with RK3066 and AML8726-MX chipsets
Postby mrspin » Fri Oct 26, 2012 5:16 am
ATV1200 now available: http://www.ovalelephant.com/index.php?r ... ct_id=2085
I've ordered one - lets hope this doesn't have significant flaws like the MK808
szantinge
Postby szantinge » Sat Nov 10, 2012 6:42 am
mrspin wrote:ATV1200 now available: http://www.ovalelephant.com/index.php?r ... ct_id=2085
Any results to report? Im curious beacuse id like one myself too.
Thanks for reporting!
userx
Postby userx » Mon Nov 12, 2012 8:28 pm
coob5
Postby coob5 » Tue Nov 13, 2012 2:43 pm
I saw on Ali-baba an HDMI stick using the AML8726-MX chipset, http://yiyate.en.alibaba.com/product/67 ... tooth.html
It looks similar to the Egreat H520. Does anyone have information on this? I have been hesistant to purchase any of these devices because of the lack of hardware acceleration for xbmc. If this device does not have any serious flaws, I think it will be a winner because of the compatibility with XBMC.
senten
Postby senten » Wed Nov 14, 2012 7:09 am
No wonder the UG802 was reduced to €38.
What are the differences between UG802 and UG802 II?
n3wb13
Postby n3wb13 » Wed Nov 14, 2012 7:40 am
Bluetooth and 8GB storage.
kokuo
Postby kokuo » Sat Nov 17, 2012 8:30 am
Hi guys,
do you know if this UG802 II is the same as the MK809 II?
http://www.mk809.com/cs102II/en/index.html
I have to buy one of those Android miniPC and I don't know if it would be better to buy a MK808 or one of those new MK809 II (that comes with 8GB and integrated bluetooth to connect a PS3 controller :P).
Do you have any info (even regarding custom firmware compatibility)?
Thank you
Kok
NWolvie
Postby NWolvie » Mon Nov 19, 2012 9:12 pm
And DC power! Good one to keep an eye on.
kenofstephen
Postby kenofstephen » Wed Dec 05, 2012 11:17 am
8726-MX is TOO HOT... :shock: :shock: :shock:
csgabe
Postby csgabe » Thu Dec 06, 2012 4:01 am
S21H Android 4.12 Pocket PC TV Box Media Player 2GB RAM 8GB Flash, bluetooth, based on RK3066:
http://www.ahappydeal.com/product-109591.html
This one is a RK3066 too, it has a different case & power button:
http://www.aliexpress.com/item/Free-shi ... 75778.html
n3wb13
Postby n3wb13 » Thu Dec 06, 2012 6:19 am
csgabe wrote:S21H Android 4.12 Pocket PC TV Box Media Player 2GB RAM 8GB Flash, bluetooth, based on RK3066:
This "S21H" could be real and it has been on sale around November but seems like it didn't get any attention?
Here is some more screenshots
> Source : 双核谷歌TV安卓电视棒安卓4.12带蓝牙2G内存8G储存-深圳寒枫科技有限公司
> [Elect] Android 4.0 on a stick - convert your TV to a Smart TV with Android ICS (from USD$40) - Page 34 - RedFlagDeals.com Forums
csgabe
Postby csgabe » Thu Dec 06, 2012 4:28 pm
csgabe
Postby csgabe » Wed Dec 12, 2012 6:49 am
New RK3066 stick with external antenna:
http://www.aliexpress.com/store/product ... 23454.html
agiler
Postby agiler » Wed Dec 12, 2012 7:17 am
This external antenna is exactly like older bluetooth dongles with fake antennas. Stay advised
csgabe
Postby csgabe » Thu Dec 13, 2012 12:32 pm
mk809 II (it has bluetooth):
http://www.aliexpress.com/item/MK80II-a ... 70537.html
MK802 IIIS (it has bluetooth, different case):
http://www.aliexpress.com/item/New-Riko ... 80447.html
gatein
Postby gatein » Sun Dec 16, 2012 7:12 am
After test.
I found Rk3066 chips up to 1.6Ghz.
But the device not run the chips for 1.6Ghz.
After test:
1. UG802 cpu 1.2Ghz, test score: 3088
2. UG007 CPu 1.2Ghz, Test score: 4260
3. MK808 CPU 1.2GHz, test score: 4389
4.MX1 CPU 1GHz, test score: 5389
5.EU2 CPu 1.4GHz, Test Score:8078
After access the Android , most custom product (this mean the operating efficiency )
No1 EU2
No2 MX1
N03 MK808 UG007 UG802 ( these model change little. and PCBA almost the same, Device alway hang,wifi instability)
this is my test result.
Mitchell4you.
Postby Mitchell4you. » Sun Dec 16, 2012 7:31 am
Those benchmark results... what did you use?
gatein
Postby gatein » Sun Dec 16, 2012 7:33 am
Mitchell4you. wrote:Those benchmark results... what did you use?
Our enginner test report.
If any others enginner could listes the test reslut. that would be more better
CruNcher
Postby CruNcher » Tue Dec 18, 2012 10:51 pm
They look like Antutu Benchmark Results, which is very common to use and very reliable :)
It shouldn't also surprise the differences depending on the cooling solutions used egrets design for example is huge compared to many others but the board itself is as small it indicates the biggest problem for optimal performance is the heat dissipation from the board. I guess this is also a reason why some of the first generation sticks fail very fast.
A good PMU + passive cooling seems to be the best solution to reach such high scores reliable :)
Here are some of my captured results from reviews not the benchmark database
Antutu Benchmark
Samsung Exynos QuadCore (Galaxy Tab 10.1/S3) (Quadcore)
Overall = 12434
CPU = 7378
GPU = 1536
RAM = 2683
IO = 837
GLBench = 15/15
Nvidia Tegra 3 (Asus Google Nexus 7) 200€ (Quadcore)
Overall = 10860
CPU = 6336
GPU = 1544
RAM = 2104
IO = 876
GLBench = 12/8.4
K3V2
Overall = 10394
CPU =
GPU =
RAM =
IO =
GLBench = 21/14
Rockchip RK3066 (Window N90 2 Dual Core) 150€ (Archos Gamepad) (DualCore)
Overall = 7803
CPU = 4067
GPU = 1546
RAM = 1486
IO = 704
GLBench = 28/20
they give some guideline what to expect from the chips itself in most probably the optimal kernel configs
you will notice that GPU is very steady and that is to be expected the biggest differentiators of the chips currently is the GPU part which on most chips is Mali 400 currently (except above Tegra3-ULP and K3V2-Vivante).
the EU2 result seems really heavy for a RockChip of what i seen so far must be running @ the edge of frequency and heat ?
Im also pretty sure from reviews i saw that either wholesellers or manufactures themselves are cheating some times with higher benchmark results running the chip @ the edge but in the final release use much lower frequencies (for reliability reasons and design costs) ;)
jlcd
Postby jlcd » Wed Dec 19, 2012 12:20 pm
Minix Neo X5 -> AnTuTu Benchmark = 9507
Return to “Rockchip RK3066”
