CWM-based Recovery for RK3066 devices
fun
Re: CWM-based Recovery for RK3066 devices
Postby fun » Sun Jan 27, 2013 8:15 pm
leolas wrote:
Morpheus123 wrote:I have a very strange problem with CWM Recovery.
After the installation of CWM on iMito X1 the device has rebooted into recovery and the air mouse was working well. Now when I reboot into the ROM and go back to recovery the mouse is not working. Is anybody experiencing such problem?
Power off the device unplug all and start it again. It happened to me one time, I did this and work, It never happened again.
I heard same issue on other devices from other people. (at least MK809II and MK802III)
one was solved(just gone w/o any fix) but another one is not solved yet.
if it will not be solved, I want to see full dmesg output both Android and CWM.
(below is not related to above issue)
on some device which has USB wifi chip connected to USB OTG port internally, default USB OTG mode may be host mode. then, adb will not work with current CWM(no UI to change mode). it will be fixed in next release(device mode will be default).
then, you may need to wait next release to get dmesg output on CWM via adb shell.
in next release, I'll change scaling size to 80% for HDMI output. if you are using TV which does "overscan", and your kernel uses larger value for default scaling size, you may see "cut off" screen. it will be fixed.
you may see wide "black border" in next release. please ignore it ;)
Morpheus123
Postby Morpheus123 » Mon Jan 28, 2013 11:58 am
When I power off the device it doesn't solve the issue. I will try to power off and unplug everything.
leolas
Postby leolas » Mon Jan 28, 2013 1:10 pm
Then sorry, that was i did and works but it never happends to me again. Dont know if it was a casuality :roll:
Morpheus123
Postby Morpheus123 » Mon Jan 28, 2013 4:21 pm
I unplugged everything from the device, connected the mouse dongle directly to the device without USB hub powered on the device and now mouse is working.
Thank you for the help!!!
leolas
Postby leolas » Mon Jan 28, 2013 4:32 pm
Nice, :grin:
fun
Postby fun » Mon Jan 28, 2013 9:09 pm
Morpheus123 wrote:I unplugged everything from the device, connected the mouse dongle directly to the device without USB hub powered on the device and now mouse is working.
thank you for your information. it helps another person.
I'll add about USB hub to "issues".
leolas
Postby leolas » Tue Jan 29, 2013 5:05 am
I am testing my compiled kernels on my mk808b, but I dont know how install them by cwm, so I need to unplug the stick and install kernel in my pc with rktools. Pls someone know how make a zip to install by cwm? link to a guide? Thanks.
fun
Postby fun » Tue Jan 29, 2013 5:36 am
leolas wrote:I am testing my compiled kernels on my mk808b, but I dont know how install them by cwm, so I need to unplug the stick and install kernel in my pc with rktools. Pls someone know how make a zip to install by cwm? link to a guide? Thanks.
extract update-binary from my zip(very important), put your kernel.img on same directory as META-INF
META-INF/com/google/android/update-binary
kernel.img
make updater-script (it's called as edify script) which has following 2 lines
package_extract_file("kernel.img", "/tmp/kernel.img");
write_raw_image("/tmp/kernel.img", "kernel");
put updater-script on same directory as update-binary
META-INF/com/google/android/updater-script
kernel.img
then, make a zip from them.
Craxx
Postby Craxx » Tue Jan 29, 2013 6:15 am
Hy Fun,
perhaps you can make a zip for kernel flashing, so we only had to change the kernel.img in the zip file. This would be awesome :-D
EDIT:
I make one, perhaps you can check, if it is ok before i flash ;-)
best regards
Craxx ;-)
leolas
Postby leolas » Tue Jan 29, 2013 8:12 am
kernel.img
kernel.img
Thanks a lot, you are the best, this will make me easyer changue kernel.
fun
Postby fun » Tue Jan 29, 2013 8:47 am
leolas wrote:Thanks a lot, you are the best, this will make me easyer changue kernel.
just a question, for testing, run adb reboot bootloader, then flash new kernel.img with rkflashtool, is faster, isn't it?
btw, there is "load to RAM" function in RKAndroidTool.exe and I want to add same function to rkflash(tool). I hope it will be best.
leolas
Postby leolas » Tue Jan 29, 2013 10:56 am
Yes but i have the stick conected to my tv, and the pc is in other room, i had to disconect it from tv , now with your zip I only need to download the zip from my homegroup, install it and test. So much easier. An the mk808B usb conectors are weak, so many times plugging and unplugging usbs will broke them.
fun
Postby fun » Tue Jan 29, 2013 11:05 am
leolas wrote:Yes but i have the stick conected to my tv, and the pc is in other room, i had to disconect it from tv , now with your zip I only need to download the zip from my homegroup, install it and test. So much easier. An the mk808B usb conectors are weak, so many times plugging and unplugging usbs will broke them.
certainly!
diniscampos
Postby diniscampos » Tue Jan 29, 2013 11:18 am
Its possible to make a recovery firmware for this ?
Primal GV-20 Mini PC (MK808-Droid Stick T10) Firmware Update V1 Download
http://depositfiles.com/files/gbnxsn9m8
My box is dead, all the flashes I made went well, but the stick don't boot... :oops:
Regards,
Dinis Campos
fun
Postby fun » Tue Jan 29, 2013 11:30 am
diniscampos wrote:Hi,
Regards,
Dinis Campos
CWM recovery is not a recovery firmware nor recovery tool to save dead box.
and here is development thread, please use another thread to ask help.
sorry.
Craxx
Postby Craxx » Tue Jan 29, 2013 12:27 pm
Hy Fun, did you checked my file ?
leolas
Postby leolas » Tue Jan 29, 2013 12:37 pm
Craxx wrote:Hy Fun, did you checked my file ?
I checked it and works ;)
Craxx
Postby Craxx » Tue Jan 29, 2013 12:45 pm
Thx so i flash later when i am at home ;-)
best regards
Craxx;-)
fun
Postby fun » Tue Jan 29, 2013 12:48 pm
sorry, I thought I didn't make any contract to make a zip or check a zip precedence over my work...
if someone can do my work for me, I can use my time for you.
Craxx
Re: AW: CWM-based Recovery for RK3066 devices
Postby Craxx » Wed Jan 30, 2013 2:38 am
No problem i checked and works great ;-)
Craxx;-)
Send from my Nexus 4 with Tapatalk :-)
Return to “Rockchip RK3066”
