New model with an Antenna for 2013
ilearner3
Re: New model with an Antenna for 2013
Postby ilearner3 » Sun Mar 10, 2013 2:48 pm
[quote="Havanafriend"]I have try the Firmware from Finless for the two clones (MK808b clone v1 or v2 finess 1.6) but only the two penguines on the screen :(
I knew it, but just try a 5V 2A power adapter(I'd same experience for twice when I flash my cx803 with other mod. ROM, black screen and then blue screen-no signal, but everything's fine when I replace the "5V 2A" power adapter with a "5V 1A" adpater, maybe it's a matter of PMU or............I'm not sure). Or you can use cx803b with AX88772b USB2.0 LAN adapter under MK808b 1.7 finless rom Until there is a stock ROM available or a ROM dump from this device.
http://www.freaktab.com/showthread.php? ... (CX803-FX5)-but-with-external-antenna-and-reset-switch-button!!!/page6
ilearner3
Postby ilearner3 » Sun Mar 10, 2013 2:59 pm
So, is there any cx803b user can provide us your dump rom?
thx.
ilearner3
Postby ilearner3 » Sun Mar 10, 2013 3:12 pm
Havanafriend wrote:I have try the Firmware from Finless for the two clones (MK808b clone v1 or v2 finess 1.6) but only the two penguines on the screen :(
Where did you buy it? Any link?
Maybe I can check out the brand and the stock ROM to help.
Havanafriend
Postby Havanafriend » Sun Mar 10, 2013 3:28 pm
I don´t have a stock rom or a dump :( i have buy it on the cebit not from a reseller and it´s from http://www.sunchip-tech.com/
ilearner3
Postby ilearner3 » Sun Mar 10, 2013 4:23 pm
Havanafriend wrote:I don´t have a stock rom or a dump :( i have buy it on the cebit not from a reseller and it´s from http://www.sunchip-tech.com/
aigo@sunchip-tech.com
No stock firmware provide?
Havanafriend
Postby Havanafriend » Sun Mar 10, 2013 4:31 pm
I sent an email to aigo@sunchip-tech.com but received no answer :(
So now i sent an email to kobe@sunchip-tech.com i hope for an answer ;)
djthomasd
Postby djthomasd » Sun Jun 02, 2013 4:58 pm
good evening to all the comunity from greece
Here to add some more problem to the allready problematic cx803 community.I have resentry purcaced a iPazzport NC19A firmware problem from tomtopshop.
its actualy a cx803 clone but the funny think is that when i have flashed finless rom 1.7 for cx803 there as no audio and my xbmc setup stopped working
after that i have reflashed all kind of firmwares made for cx803,v8.fx5 everything i have found on the new with the same results NO AUDIO (device manager shows no audio device but it can load usb audio perfecly)
so i try to flash on it ug-802 finless rom and sound worked (no wifi but that was expected and rom crashed on first reboot if you was trying to activate it)
so i have opened and i have seen something that was never reffered in here before
motherboard type is cx-803 v1.6 13021
i have send emails to all the manufactures and supplyers (ipazzport.cn ipazzport.us tomtopshop) but still no reply
So my only hope now is to install MK802iiis image and use it with a usb wifi donkle from tp link that uses the same rtl chip as the original mk802 have
dont know if is gonna work but i will know soon
I have spotted another member complaining that no audio on the device and im kindy ask him to open it and check if there is the same hardware to comfirm the kernel issue (topic here viewtopic.php?f=4&t=1685)
Edit
Same issue with mk802iiis firmware also
Audio is on but no wifi
what is wrong with the kerner on this version of cx803?
