Flip Case for the iNew i2000
Postby deadhp1 » Wed Apr 10, 2013 11:04 pm
So I had previously mentioned that the iNew i2000 was the upgraded version of the Changjiang N7300 and that some accessories would fit.
Well today I received the N7300 Flip Cover case I ordered from Geekbuying.
http://www.geekbuying.com/item/Protecti ... 13612.html
http://www.geekbuying.com/item/Protecti ... 13898.html
It fits perfectly! I finally have a way to carry around the i2000 without worrying about the screen.
I ordered the cover in grey because my i2000 is white and I wanted a 2-tone look.
The flip cover is actually a replacement for the battery cover with a flip cover attached to it.
It does make the phone a TINY bit thicker, but not really noticeable.
What is noticeable is that the camera no longer protrudes out the back of the i2000. Instead it is nearly flush if not sunken in slightly.
I'm much more comfortable laying the phablet on it's back now.
The extra added thickness also make me think it would be possible to run the 3200mah battery from the N7300. I'll be ordering that battery soon.
I still have some screen covers on route to me and will post up when I receive them.
Return to “Working Peripherals”
