USB to RJ45 (Ethernet) Adapter
blackk
Postby blackk » Tue Oct 30, 2012 8:21 am
1. JP1082 RD9700 [Not Working]
2. BobjGear ASIX AX88772A [Need Testing] (working, reports of other devices Telechips)
3. SYBA SY-ADA24027 ASIX AX88772B [Need Testing] (working, reports of other devices Telechips)
Red: Chipset
csgabe
Re: USB to RJ45 (Ethernet) Adapter
Postby csgabe » Sun Dec 23, 2012 3:23 pm
Here are some drivers for usb lan(asix & moschip chipsets):
3.0.8-tcc.tar.gz
You have to do:
Code: Select all
insmod mii.ko
insmod usbnet.ko
insmod asix.ko
insmod mcs7830.ko
pawelkrak
Postby pawelkrak » Sun Jan 06, 2013 8:07 am
Hi :)
Can u tell me, how can i put these drivers into my CX-01 ? Im not a specialist in LINUX.
Veronica
Postby Veronica » Sun Jan 06, 2013 1:17 pm
Can someone tell if this 2 adapters are the same, perhaps @geekbuying itself can reply :P
http://www.amazon.com/Compact-Fast-Ethe ... B007RTACDM
http://www.geekbuying.com/item/USB-2-0- ... 13020.html
They look the same but different package plus the one from Amazon is expensive comparing to the one provided by geekbuying but in the geekbuying webpage they don't provide chipset info it is why im asking here, thanks in advance!
~ V
djshark0
Postby djshark0 » Thu Jan 17, 2013 5:51 pm
Hi guys, i'm new and i saw this post because i have the same problem of the pawelkrak, i don't know how can put this driver on the iMito MX2 it's the same approximately, Please can same body help us, thanks in advance :D
Return to “Working Peripherals”
