RC11+RC12 Fly/Air Remote Mouse works
raybat
Postby raybat » Thu Oct 04, 2012 4:08 am
Just an update to say that i tested both RC11+RC12 Fly/Air Remote Mouse with the MK 808 and found them to be working.
Next week, i will be testing with Lenovo N5901A and will post my results then..
If you do need any MK808 device, kindly PM me off-line.
alca51
Re: RC11+RC12 Fly/Air Remote Mouse works
Postby alca51 » Wed Oct 10, 2012 5:45 am
Worked for me too.
Is there a way to remap the keys? ctrl, alt and F1 to F12 doesn't work.
KEgg
Postby KEgg » Thu Oct 11, 2012 10:46 am
If you're using a rooted version of JB or ICS for Mk808, you can edit the generic.kl file to suit your needs. Use either 'ES File Explorer', or 'Root Explorer' to make modifications. Personally I use the 'Root Explorer' as it leaves file permissions and owner information correct, and creates a backup of the file you're editing.
szantinge
Postby szantinge » Mon Oct 15, 2012 8:04 am
Works for me too, adjusting the pointer speed a bit lower works for me better. Other then that I prefer this one over a normal mouse, because Im using it on the couch. :D
cyberbol
Postby cyberbol » Sat Oct 20, 2012 11:40 am
Hi
Which keyboard is best?, better control etc...? for MK808
1. RC11
2. RC12
3. Lenovo N5901
Thx for reply.
tashkas
Postby tashkas » Thu Nov 08, 2012 3:09 pm
i have problem with rc12. when i try to type word i get multiply clicks-letters at once. and i cant type normal on it how to solve it? but if i connect it to pc everything works fine.
nybom
Postby nybom » Fri Nov 09, 2012 8:24 am
tashkas wrote:i have problem with rc12. when i try to type word i get multiply clicks-letters at once. and i cant type normal on it how to solve it? but if i connect it to pc everything works fine.
http://www.freaktab.com/showthread.php? ... #post32954
tashkas
Postby tashkas » Fri Nov 30, 2012 11:15 am
no it dont work good in otg port too. does anybody solved that problem? on pc it works great.
rami
Postby rami » Wed Dec 19, 2012 6:47 pm
I had the same problem. It was solved by connecting the dongle through a usb extension cable. 0.5m length seems to be more than enough.
sampu
Postby sampu » Mon Feb 04, 2013 3:14 am
Thanks a lot "rami" for your suggestion ; now, my RC12 works flaw-less and smooth after connecting the RF receiver to a usb-extension-cable. No more repeat characters and I feel better control on the mouse movement.
vsg
Postby vsg » Thu Feb 14, 2013 3:23 am
Hello all, I have mk808, which I absolutely love and it came with an RC12 remote, which I am not really in love with!!
As a number of other users, I am having the same problem of keyboard sensitivity, however nothing I do seems to work (and I have tried as long as 6ft extension) so now I have a couple of questions, which I hope someone will be able to help me with.
As we know this problem is caused by some wifi interference, does the fact that my router is pretty much next to the stick, have anything to do with it? In which case, if I move the router away or start using Ethernet, will that solve the problem ?
Is this problem exclusive to RC12 or other controllers (mele f10 in particular) have similar issues ?
I am on finless 1.6 rom, will going back on the official firmware make any difference ?
And finally, I was reading at another forum, that this issue could be resolved by lowering the sensitivity of keyboard in settings, but I did not find any such settings, is that something at all possible on Mk808?
Sorry I know that is a lot of questions and thanks in advance for all the help
iantresman
Postby iantresman » Sun Feb 17, 2013 7:43 am
Is anyone aware of an app that will allow the function key shortcuts to be programmed, and to work? Presumably the MK808 receives the key press information.
RmatriX1218
Postby RmatriX1218 » Sun Feb 17, 2013 11:10 am
iantresman wrote:Is anyone aware of an app that will allow the function key shortcuts to be programmed, and to work? Presumably the MK808 receives the key press information.
Try modifying kl file, Google it.
Or try external keyboard helper. Search on play store.
