Which USB Sound Card?
craleu
Re: Which USB Sound Card?
Postby craleu » Wed Oct 24, 2012 4:48 pm
http://developer.android.com/about/versions/jelly-bean.html
state that JB supports it by default?
Im using the Fitness JB rom and usb sounds does not work :(
kmunir
Postby kmunir » Sun Oct 28, 2012 7:49 pm
I think this works in the latest JB beta firmware. Options are there and it does recognise my generic usb sound card as well. Will try tomorrow for sure and let you know
craleu
Postby craleu » Mon Oct 29, 2012 3:27 pm
it shows up, but no sound output in finless 1.5
kmunir
Postby kmunir » Mon Oct 29, 2012 7:46 pm
Yes no sound output for me too. Although a Mic worked fine with the same sound card. I'm using rooted latest beta
thomasli
Postby thomasli » Sun Nov 25, 2012 6:42 am
I got a USB 3D sound 5.1 card. I can't get it work at first when I plug it in the OTG usb socket. Android recognise it but no sound out. Later I plug it in the usb socket adjacent to the hdmi out. It works.
I am trying to connect the tv stick to pc monitor but with only vga in. I use a hdmi to dvi adapter and a dvi to vga adapter. but no signal out. Any cue?
genosyde
Postby genosyde » Mon Nov 26, 2012 11:39 pm
A simple HDMI to DVI/VGA adapter will not work on a VGA only monitor because HDMI is digital but VGA is analog. If you have a newer monitor with DVI and VGA, it can probably work with the DVI input as that is digital as well.
To accept a HDMI input on a VGA only monitor, you need a HDMI to VGA converter. This is also true for HDMI to RGB Component conversion.
http://wizzley.com/hdmi-to-vga-and-rgb- ... converter/
julandroid
Postby julandroid » Wed Nov 28, 2012 6:18 pm
thomasli wrote:I got a USB 3D sound 5.1 card. I can't get it work at first when I plug it in the OTG usb socket. Android recognise it but no sound out. Later I plug it in the usb socket adjacent to the hdmi out. It works.
Can you please tell me which usb sound card (link?) model do you use and also which MK808 firmware version you have? I'm still confused about usb sound support. One tells me the USB sound support is *only* available in ICS, but not in Jelly Bean. Is that true? Can anyone tell me what do I need to do in order to enable the usb sound on the JB!?
Edit: The solution was easy - I had to update to latest JB firmware and the use sound card was recognized.
carlos
Postby carlos » Sun Dec 09, 2012 5:18 am
Virtual 5.1-Surround USB 2.0 External Sound Card
works fine, but only behind the USB port, not behind the USB otg!
http://dx.com/p/virtual-5-1-surround-usb-2-0-external-sound-card-22475
white-enochian
Postby white-enochian » Mon Dec 24, 2012 3:00 pm
i have the samesound card 3dsound right on it.
it does not work in my mk808
i plugged it in and nothing happens is there a setting to change or is android not seeing it or is it broken.
its a 3d audio usb thing looks like this onehttp://tabletrepublic.com/forum/andr ... -3092.html which makes me believe it should work
my settings screen looks nothing like that
the only thing i have under the sound tab is volume
also on his it says data storage on mine it says storage.
i also dont get that pop up notification ether.
here is the exact one i baught
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... TM:US:1123
Wig42
Postby Wig42 » Sat Feb 02, 2013 2:15 pm
I ordered this a whioe ago, shipped from HK. I'd actually forgotten about it until it turned up this morning.
http://www.amazon.co.uk/Speaker-Audio-S ... ys_iyr_img
Plugged it in, settings showed up straight away on sound page. Works perfectly.
Pleased it does or it would have been a waste of 74 pence LOL. Seriously how can they make and mail this for 74 pence. Nevermind main thing is it works great.
btw I'm using lewy's 2.1.0 FW & 2Dark4U's 1.4 kernel (Great combination btw, brilliant work both of you guys)
Wig
gray77
Postby gray77 » Mon Apr 22, 2013 12:36 pm
When you add a USB sound card dose the HDMI sound going to the TV stop working or can you use them together?
