Eanovo EATV005
Have a device not listed here? Make a request for a forum.
ONLY for new forum requests.
Mitchell4you.
Eanovo EATV005
Postby Mitchell4you. » Sun Dec 09, 2012 10:02 pm
Eanovo EATV005 ne : Brand Name, Eanovo/OEM tv box. Model Number, EATV005 (from ebay : Uk dealer )
Info : http://eanovo.en.alibaba.com/product/63 ... v_box.html
CPU: ROCKChip 3066 Dual Core 1.4GHz CPU (1412mhz)
Operation System: Android 4.1.1 Jelly Bean (rom v1.0.3)
GPU: Quad-Core Mali 400MP
GPU Memory: DDR2 1GB
Storage: NAND flash 4GB ( 512mb internal / 2.11 gb internal sd )
Support external SD card up to 32GB
Network: WIFI: IEEE 802.11 b/g/n
Rj45 network connection interface
Videa/audio out : RCA & HDMI ( at the same time )
USB connectors : 4
Power : DC adaptor 5v 2a
The bad :
512 mb internal nand, means running out of install space quikly
Because sadly not all app support moving2sd
No manual
No remote
No root
The good :
Video & audio from HDMI and RCA at the same time ( HDMI Monitor / RCA to Scart to CRT TV )
So, I connected the RCA to my AV-Reciever (stereo to surround 5.1 ) and was happy supprised it worked
I can play music with-out any monitor running (just hitting key play on keyb :meridan plays from hd)
Installed/played XBMC, Youtube and many more app without any issue (from rj45)
Playing 4:3 streaming video : I was happy supprised the video wasn't stretched (like it does on my mk808stick)
a notice:
Setting up lan or Wifi after your settings are saved, the device doesn't connect (it needs a reboot to work)
Not tested Wifi...
user exp : for this device 2 days ( i also have a mk808 1month and ?? stick 3months )
ps
What do use to make screenshot?
If you have questions, just reply :-)
I think... I posted this in the wrong place ? ( should probably be tvbox section)
Return to “Forum Requests”
