Hello All,
how about a forum topic for the Dual Core MK806 Stick with the 3,5 Line Out and the blue cap?
Specification MK806:
- CPU Rockchip RK3066 1.6GHz Cortex A9 Dual core
- GPU Mali400 Quad core, 2D/ 3D/ OpenGL ES2.0/ OpenVG1.1.
Video Decoding: Support 1920x1080p@60fps
Video Encoding: Support encoding in H.264. 1080p@60fps, 720@100fps
- Operation System Android 4.1 Jelly Bean
- RAM 1GB
- Nand Flash 4GB
- Support TF Card up to 32GB
- WiFi 802.11b/g/n
- Support USB 2.0 Wired Keyboard/Mouse; Support 2.4G Wireless Keyboard/mouse;
- HDMI Interface Support 1920x1080P @60Hz Full HD Video output
- Physical botton ( For upgrading software+ Copy File)
Ports:
- USB Host ( support External USB port RJ45)
- Micro USB OTG
- Standard HDMI port
- 3.5mm Earphone
- TF card Slot
Greetings,
Wille
MK806 (Rockchip RK3066 1.6GHz Cortex A9 Dual Core)
Re: MK806 (Rockchip RK3066 1.6GHz Cortex A9 Dual Core)
I'm thinking of buying a MK806. Could you write something about it, like how is the wireless connection(speed, stability), about video playback(is the video in sync with the audio), who is the manufacturer(does he provide firmware updates). Is the firmware stable enough?
First of all: You can root the MK806 with the rooting-tool for the MK808,this works fine.
I had to "optimized" the wifi- antenna - I opened the stick and put the internal antenna out -I have attached a picture. Since this moment I have excellent speed an stability, I can stream YouTube 1080p videos. Video and audio are in sync, I have no problems. Without this modification wifi is a mess.
Original Manufacturer is unknown, I got the stick from aliexpress. I also got a img-file from the dealer at aliexpress.
Bluetooth is not included, but work with some, not all, adapters. I am able to connect to external bt.-keyboard, but only in a terminal session. The build-in bt-settings from android in the setting-menu do not work.
I had no problems with the firmware until know, adb-connection also works well over usb-cable.
OK? Greetings
Wille
OK? Greetings
Wille
It seems the MK806 and the MP802 are the same device. I've made a forum for you guys in the Rockchip RK3066 section.
Looks like a sweet little device.
Anyone want to post the dmesg output?
I'd also love to get a copy of the firmware to put up.
hi deadhp1,
thanks for open up the forum for the mk806.
I have already posted my firmware link in the firmware sub forum here: viewtopic.php?f=117&t=877#p5319.
I will create and post the dmesg output by the end of the week.
Greetings,
Wille
Greetings,
Wille
Hello, sorry my bad english...
I have problems with the wifi mk806, is very unstable ...
what better way to open the stick and put the antenna out?
Thank you!
Thank you!
Hello
firmware for this MK806 and MK808 compatible?
rgomes wrote:Hello, sorry my bad english...
Thank you!
Hi rgomes,
wifi signal and performance issues are common problems with the android sticks.
Some people tried to use usb-to-ethernet adpters, some use wifi-antennas from notebooks, others upgraded there sticks with "hardplastik" wifi-antennas. Pls look in the MK808 subforum for hints or use the forum search function.
Greetings
Wille
Sergey9000 wrote:Hello
Hi Sergey,
until now I have not tested to use the MK808 firmware with the MK806. I myself think, that there is a good chance, that the MK806 will work with the MK808 cyanogen mod (without warranty). Build in hardware seems to be similar.
Pls leave a post with your experience when you try to install the MK808 firmware in the MK806 forumsection.
Thx, greetings
Wille
Hi!
I have tested many firmwares from MK808 and others miniPC on MK806. But every firmware doesn't support 3,5mm audio output. Everything else is working very good!
Also tested original firmware from Kindecent with replaced kernels. Also no audio output. Only supported audio thru hdmi.
Can anybody tell me what can I do to get 3,5mm audio jack working? I think there is something in kernel, but I don't have knowledge about it.
wirusek68 wrote:Hi!
Neomode has been kind enough to create a kernel that will work with audio output and finless rom:
http://www.freaktab.com/showthread.php? ... audio-woes
But me I have latest mk806 with bt and loose wifi and bluetooth.
But at least audio works.
I wonder if someone knows how to get the latest official firmware for mk806 bluetooth version.
