mk812
Have a device not listed here? Make a request for a forum.
ONLY for new forum requests.
darvon1
mk812
Postby darvon1 » Sun Feb 10, 2013 4:02 am
I have flashed varius builds to this device and i have yet to find one with working wifi drivers..Now I just want to flash the stock firmware but can not find it any where.Does anyone have anything on the mk812 http://miniandroidpc.com/shop/mk812-dua ... -bluetooth
Im stuck with an android with no wifi....
darvon1
Re: mk812
Postby darvon1 » Sun Feb 10, 2013 8:30 pm
update...Found the mx1 builds to work with wifi but nothing else...Is there a way to extract the wifi drivers from this mx1 build so i can install them manually with other builds and if so where are they located in the file system...Thanks
gianpaoloc
Re: mk812
Postby gianpaoloc » Tue Feb 12, 2013 5:38 am
darvon1 wrote:update...Found the mx1 builds to work with wifi but nothing else...Is there a way to extract the wifi drivers from this mx1 build so i can install them manually with other builds and if so where are they located in the file system...Thanks
If the mx1 firmware works this means it has a Mediatek MT5931 wifi chip (and probably a Mediatek MT6622 bluetooth chip). This is the sam chip used in several tv keys including imito mx1, mx2, mk809ii, mk802iiis, ug007. You can probably use the Finless rom 1.5 for mx1 (look at freaktab site). It is a very good rom, which supports those wifi and BT chips perfectly.
You can also follow this thread: http://www.freaktab.com/showthread.php? ... on-the-mx1 where a couple of people are trying to find a way to compile their own kernel re-using the binary modules for wifi and bt.
Hope this helps
G.
darvon1
Re: mk812
Postby darvon1 » Wed Feb 13, 2013 11:40 am
thanks ! i am using the finless rom it is great... the mk812 also has a mic and camera , any ideas on getting those to run?
rainymanyu
Re: mk812
Postby rainymanyu » Mon Feb 18, 2013 6:35 pm
any progress? how u r satisfied all in all? any issues? did u try it at all on stock rom, the one that it came with?
I am seeing this device as currently best option for the price.. Do u have any advice or recommendation? 10q
majack
Re: mk812
Postby majack » Thu Feb 28, 2013 6:52 am
soliveira
Re: mk812
Postby soliveira » Fri Mar 15, 2013 6:54 am
I have only found this forum after installing a rom that has the same problems that is commented here. I also don't have the stock Rom for the B13, and Kimdecent hasn't answered my emails. Was there an evolution on this subject?
I am thinking of trying this one: http://vondroid.com/threads/b13-mini-pc ... 2013.7070/
If someone has any news to share would be appreciated.
Thanks,
Sérgio
Re: mk812
Postby deadhp1 » Fri Mar 15, 2013 10:08 am
you could try the Measy U2C firmware on this device.
It should support the camera, wifi, and bluetooth.
soliveira
Re: mk812
Postby soliveira » Fri Mar 15, 2013 9:47 pm
The measy U2C rom was the one that put the wifi and bluetooth, among other things, out.
But I have solved the problem using the firmware I have indicated before. I can confirm it is the stock firmware for B13. Works again.
But it is not rooted.
Maxrunner
Re: mk812
Postby Maxrunner » Fri Mar 22, 2013 10:45 am
How do you flash roms in this without the seller software?
ralbright
Re: mk812
Postby ralbright » Tue Apr 09, 2013 11:45 pm
I do have the stock 4.2.1 AND 4.1.1 ROMS for the MK812 with and without antennas, They are rather large.
Return to “Forum Requests”
