UG802 Fixer apk from 4pda.ru website
Apps and Software Mods for the UG802.
eCCoMaNia
Postby eCCoMaNia » Sat Oct 27, 2012 5:31 am
hello, I found an apk for ug802 and wanted to share with you
This is for stock firmware only
here is the google translate of this apks features;
1. switch permits 1360h768
2. swap SDcard and External_SD (external system sees as an internal card and puts the program there) has the problem with some programs
3. reconnect the system permissions.
4. corrects build.prop:
4.1 Changes the TCP buffers to speed WIFI and USB Ethernet
4.2 Changes the density of points in the image 160dpi/120dpi (all will become smaller or larger)
4.3, the set of tweaks.
4.4 Program GOOGLE switch to tablet mode
4.5 prohibits programs rotate screen.
4.6 allows sleep (then add a few keys that will turn off / put to sleep the beast)
Here is a test version, there is only 3 buttons 1360h768, 1440h720 and Tweak (in build.prop VM heap size = 128mb LCD density = 120DPI and enabled shutdown, else tested)
Requires ROOT
All credits to 2dark4u (russian developer)
here is the link;
http://dl.dropbox.com/u/39462568/UG_fixer.apk
userx
Re: UG802 Fixer apk from 4pda.ru website
Postby userx » Sat Oct 27, 2012 7:29 am
This app put my unit in boot loop.
Test was a fail.
Not sure what it did but all my old setting are out of wack.
Gona have to do a system recovery or reflash.
Test at your own risk.
eCCoMaNia
Postby eCCoMaNia » Tue Oct 30, 2012 12:13 pm
userx wrote:This app put my unit in boot loop.
Test was a fail.
did you try with stock firmware of ug802 ?
Return to “Apps and Software Mods”
