Tronsmart T428 Quick Preview!
Postby deadhp1 » Fri Mar 08, 2013 10:13 am
Geekbuying has a new quad core tv stick coming in the beginning of April!
It's call the Tronsmart T428!
The T428 has the following specs:
1.8Ghz Rockchip RK3188 running at 1.6Ghz
2GB of Ram
8GB of Nand
Wifi b/g/n
1 Full size usb port
1 Micro-usb port(for power)
Micro-sd slot
Male HDMI connector
Reset button
For more info check out Geekbuying's post at:
http://blog.geekbuying.com/index.php/20 ... pc-coming/
lefizz
Re: Tronsmart T428 Quick Preview!
Postby lefizz » Fri Mar 08, 2013 12:33 pm
Looks really interesting. I think after buying a couple of sticks the next unit i go for will be a TV box type thing but i guess it depends. Can't wait for more quad core units hopefully with 4.2
Sent from my ZP900 using Tapatalk 2
Castaa
Postby Castaa » Fri Mar 08, 2013 3:03 pm
Can't wait to see Ubuntu running on one of these. :D
Porting from the RK3066 shouldn't be that difficult, right?
SpicySaturdayBoy
Postby SpicySaturdayBoy » Fri Mar 08, 2013 5:24 pm
Another rk3188 stick called "CloudnetGo CR9" coming out too...
http://www.cloudnetgo.com/_d275871049.htm
vibescu
Postby vibescu » Sat Mar 09, 2013 4:06 am
SpicySaturdayBoy wrote:Another rk3188 stick called "CloudnetGo CR9" coming out too...
Full specs here:
http://androidpc.es/blog/2013/03/07/especificaciones-finales-del-tv-stick-quad-core-con-rk3188-de-cloudnetgo/
JugsteR
Postby JugsteR » Mon Mar 11, 2013 3:38 am
Full specs here:
The difference is that the T428 has Bluetooth and the other one has an extra USB port. Wonder if the GPU will ever have proper Linux drivers though. Shame if it doesn't.
Signature? Signature!
Castaa
Postby Castaa » Fri Mar 22, 2013 5:32 am
geekbuying wrote:Here is some more news about Tronsmart T428
http://blog.geekbuying.com/index.php/20 ... e-release/
That's good news.
pellemando
Postby pellemando » Mon Apr 08, 2013 3:33 pm
Anything new about this one?
I really want a quad core android TV stick, and I think this one will be the most stabile, but it is taking to long time :P
muratremix
Postby muratremix » Tue Apr 16, 2013 8:33 am
Did geekbuying sent these devices on April 10?
pellemando
Postby pellemando » Tue Apr 16, 2013 1:30 pm
dont think so
and no updates from tronsmart about the casing.
Postby deadhp1 » Thu Apr 18, 2013 7:12 pm
I ordered one of these so I hope to have a review up within the next week or 2. Stay Tuned!
BTW geekbuying posted pics on their blog of the casing.
http://blog.geekbuying.com/index.php/20 ... view-here/
etatto
Postby etatto » Sat Apr 20, 2013 6:58 am
Could someone acknowledged if a serial access is still present on the production board, as might be seen on the beta board shown on GeekBuying blog ???
Thanks. :D
Postby deadhp1 » Sat Apr 20, 2013 5:02 pm
Most likely it is still there. I'll know more once mine gets here.
I was also planning on soldering to those points.
linuxium
Postby linuxium » Fri May 03, 2013 11:29 pm
Yes the serial access is still there with labeling (T,R and G) and works fine with Minicom - I've uploaded the boot up sequence for 4.1.1 as an example here: https://docs.google.com/file/d/0B99O3A0dDe67TXhsX0lfUWpXRFk/edit?usp=sharing
Return to “Tronsmart T428”
