K-R42 Kingnovel Android TV Box Rooted 4.2.2 Stock Firmware
Postby lewy20041 » Fri Jun 28, 2013 4:40 am
I need a tester to check if it properly rooted becouse i dont have this box.
If i found this device popular i consider makeing a custom firmware for it.
If you like you can check out my website and press facebooke like buton.
You will find there some nice apps for your TV stick/box.
http://apkfreak.com
Download:
FreakTab Cloud
Polish users support
http://android-minipc.pl/
muratremix
Re: K-R42 Kingnovel Android TV Box Rooted 4.2.2 Stock Firmwa
Postby muratremix » Fri Jun 28, 2013 11:37 am
Can you make custom roms for iMito QX1?
Postby lewy20041 » Sat Jun 29, 2013 5:51 am
Maybe when I get this device.
Donations are welcome;p
For now it will be just for K-R42 becouse
Geekbuying will send one to me.
bert21
Postby bert21 » Sun Jun 30, 2013 12:33 pm
hello lewy20041
glad to see that geekbuying has sent you a free K-R42.
i had one of your roms on my neo x5 and it was very good.
my plan was to use the K-R42 as a dedicated xbmc device.
is there any chance to boot xbmc directly?
So without Startup Manager, maybe an xbmc lewy20041 boot animation.
and only the basic necessary android apps
Mitchell4you.
Postby Mitchell4you. » Sat Jul 06, 2013 3:27 pm
some questions :
1, is the kr42 the same as the cs918 ?
i read on geekbuying that kr42 doesn't have bluetooth ( most sellers report it does)
2, Does it have bluetooth ?
3, if it doesn't have bluetooth will it support a external one ?
4, does the 'statusbar' hide, when running xbmc?
5, does the firmware include the 'libstagefright' patch ?
ps... great to see, ppl hard at work fixing firmwares... like the partition fix on the kr42 :-)
i ordered the cs918... yesterday (sadly, i have not seen any reviews yet)
two cheers... for developers :-)
Postby lewy20041 » Tue Jul 09, 2013 4:11 pm
1. it looks the same but im not sure:"
2. for now it dosnt heve BT, but eric from geekbuying said that new buch will later this month.
3. i will work on it.
4. probably not will try to implement it.
5. no. i will see if can implement it to.
Mitchell4you.
Postby Mitchell4you. » Fri Jul 26, 2013 11:49 am
well.... i got my answer
my CS918 just came-in... no bluetooth... and the pcb looks the same as pic from geekbuying (k-r42)
running 720p kernel it seems (refusing to goto 1080p gui)
still... not bad (first impression is good)
SilentlyScreaming
Postby SilentlyScreaming » Fri Nov 29, 2013 3:07 am
A bit late to this thread, but just wanted to clarify that when some vendors report Bluetooth, they actually mean the OS has the required drivers/kernel thingies ( :) ) to support external bluetooth dongles.
I've run across a few Chinese-based shops that list bluetooth in the spec, but eventually can be made to realize that people will infer this means there is bluetooth hardware within the Android stick/box.
Just thought I'd post this for future visitors wondernig...
Return to “Rockchip RK3188”
