Simple and Working Wifi Antenna Quad Mod
Dero
Postby Dero » Thu Dec 20, 2012 8:59 am
Hi, I was looking at the mods some of you guys did and "invented" my own mod, base on a a round quad-antenna.
AFAIK, the shape of a quad antenna is not really important, only the TOTAL length of the cable has to be equal to the wavelength times the copper shortening factor (0.975), hence roughly 12 cm.
What I did:
- completely removed both built-in antennas
- clipped off the two antenna pins (the one close to the USB port), MK808 v1 doesn't have pins
- soldered a 12 cm piece of copper wire with one end to GND pad and the other end to ANT pad, the ones close to the USB port (take care that you don't kill one of the pads)
- drilled a small hole into the case
- bent the wire like an ear
Works very well! 100MBit download from internet improved from 16 s to 4 s, i.e. from 6 MBit to 24 MBit.
Be aware that the antenna is directional. In theory, that's the optimal positioning:
- let's assume the MK808 stick is a head, where the OTG port is the nose, the HDMI port is the throat, and USB+power is the scalp
- then the antenna is the right ear
- assume you have a wifi router with a normal rod antenna
- the rod-axis and the stick-head-axis must be parallel, i.e. if rod is standing upright, stick must stand upright (to have the same polarization)
- the nose of the stick-head must point into the direction of the rod, i.e. the quad-antenna is facing planar to the rod
I tried also to extend the antenna to a biquad by soldering another copper wire to the other GND/ANT pads (close to OTG port), but somewhy the signal dropped badly and I removed it again...
dero
BTW. I have another stick, where I killed both ANT pads while trying to solder and I can't get any wifi anymore. However, I could get an Edimax ew-7811un to work. But, I would love to fix the antenna pads. Does anymore know a bit about the circuit wiring of the MK808, i.e. where could I attach the antenna to?
itsme
Re: Simple and Working Wifi Antenna Quad Mod
Postby itsme » Mon Dec 31, 2012 5:59 pm
This works.
Plus extra kudos for the Picasso face/head/antenna description, really into surrealism there!
Dero
Postby Dero » Mon Dec 31, 2012 6:35 pm
Thanks!
BTW, I get even better reception if I squeeze the antenna to look more like an elliptical folded dipole than a circle-quad, i.e. push the outer side of the ear to the head until roughly 1 cm is left.
 ____________________
\_________  _________/
        GND ANT
^single core wire with roughly 12 cm (one wavelength 12.4 cm multiplied by copper velocity factor of 0.97) soldered between GND and ANT and bent to a folded dipole.
I also experimented with a reflector: put a metal plate 14 mm behind then antenna. A bit of gain, but not worth the PITA to glue it to the right position...
Dero
firefly1010
Postby firefly1010 » Sat Jan 12, 2013 5:16 pm
Works like a charm :D
I can even see my neighbours Wi-Fi, which is in a house 20M away
Here is how mine looks.
Dero
Postby Dero » Sun Jan 13, 2013 4:25 pm
Good work!
Your antenna looks very "lathy". I got even better result "pushing" it down to look more "fatty" (folded dipole).
dero
nimo
Postby nimo » Tue May 13, 2014 11:33 am
Hey guys,
I have a mk808 and close to the router there is no issue but when its few meters away then there is a sudden drop in reception and speed
My device has two antennas, one clearly visible, grounded and the second one is a pogo meaning it presses agains the antenna piece (both ground and antenna)
What I did following some of the recommendation:
Unsoldered the ground and left only the antenna and for the second one, I put a a block so the ground is not active anymore
I saw some kind of improvement but can you recommend me what to do?
Is it best to use the copper wire 12 cm length on both side of the board or one specific?
Is it best to use an eternal antenna to soldered to the ANT of one side of the board? and not the GRD?
Thanks in advance!
nimo
Postby nimo » Thu May 15, 2014 8:26 am
Hi Dero,
Could you please tell me how you got the wifi adapter Edimax ew-7811un to work with your MK808?
Thanks in advance
nimo
Postby nimo » Wed May 21, 2014 7:11 am
burekas
Postby burekas » Tue Feb 17, 2015 9:11 am
I tried this mod, but the wifi signal is not stable.
I soldered it to the Ant which is near the OTG, maybe the pad was damage or something.
If I will do this mod to the second Ant, and I don't have the 0_Ohm resistor, should I put there a resistor or short between the resistor pads could be good also?
And the second question, Do I must pull off the clips or can I solder it on them? (Put a paper of course to prevent it touch the stick antenna)
Thanks.
