External Antenna?
craleu
External Antenna?
Postby craleu » Fri Oct 19, 2012 5:52 pm
Would it be possible to remove the wifi plates and solder like a router antenna to them?
I've ordered an antenna will post photos of signal improvement
ginopaneg
Re: External Antenna?
Postby ginopaneg » Sun Oct 28, 2012 7:00 am
news for this?
stuff like that could be useful?
http://www.ebay.it/itm/ws/eBayISAPI.dll ... &hlp=false
mumin0
Postby mumin0 » Sun Oct 28, 2012 4:34 pm
hallo this one is easy... pigtail
http://yc-antenna.en.alibaba.com/produc ... ector.html
use one of those (best nr 6) x2 solder to the place of current antennas and use antennas what ever You want 8-)
only thing is if the device can power the antenna if it will be 7dbi x2 :mrgreen:
I will do the same with mine when it comes and will have problem with connectivity.
I used those to upgrade wifi usbs in good old wardriving times :lol:
by the way why none try it for mk802 when it had so poor antenna inside :?: :!: :idea:
edit: i was wrong someone already did it :twisted:
https://www.box.com/s/qi8czy3e067j8fza4tw8
http://www.rikomagic.co.uk/forum/viewto ... 0&start=40
retlif
Postby retlif » Fri Nov 02, 2012 2:40 am
I am interested in this hack too.
However, I don't have much experience tinkering with external wifi antenna... :oops:
I received mine. No wifi drop out, line-of-sight abt 1.5m gave me 3 bars. It would be fun to do some modding on my new toy :lol:
siocran
Postby siocran » Thu Nov 08, 2012 6:00 pm
hello, I preferred to solder directly antennas of an old router making holes with a drill.
this is the result
devil66663
Postby devil66663 » Mon Nov 12, 2012 1:49 am
Hello guys
Take 2 Wires with 6,3cm lenght and solder it to each ANT pad.
You will see it works.
Very important: Do not use the original antenna Cable.
The Chinese have built crap in the Production, and produces a short circuit at the antenna Cable.
Regards
Bernhard
fratello
Postby fratello » Sat Dec 22, 2012 5:20 am
@Siocran : I just bought 2 external WiFi antennas, like yours, and I intend to do the same modding.
Can you tell, it's a REALLY improvement in WiFi reception ? Thanks in advance !
