How to trigger Reset on this one?
ratpen
Postby ratpen » Wed Feb 06, 2013 5:59 pm
I want to flash the firmware but couldn't get Windows 7 to recognize it when plugged in to USB while holding down reset button with a needle.
Like described here: viewtopic.php?f=13&t=45
So i opened the case and didnt even found a reset button where it should be. As you can see in the attached pic, there is nothing in the bottom right corner.
It should look like this:
http://blog.geekbuying.com/wp-content/u ... river1.jpg
So where is my reset button? Or how can I flash the Firmware without it? Already updated via SD-Card to recent Stock release.
Would apreciate any help. I have no experience in soldering or anything like that.
ratpen
Re: How to trigger Reset on this one?
Postby ratpen » Thu Feb 07, 2013 4:00 am
SOLVED
I bridged the missing button by holding a paperclip onto the the two silver thingies in the bottom right corner while plugging the usb into OTG.
FergusL
Postby FergusL » Thu Feb 07, 2013 11:11 pm
What is this version you have ? Is it an Ipegtop ? I've found these but don't know if I should get one.
If this board doesn't allow to post links, I'd appreciate that you pm it to me !
It doesn't look the same, indeed.
Thanks !
