Pictures of PCB
Hardware Mods For the MK808.
Pictures of PCB
Postby deadhp1 » Fri Sep 21, 2012 4:49 pm
BooLE
Re: Pictures of PCB
Postby BooLE » Wed Sep 26, 2012 11:45 am
Hi deadhp1,
can you please verify existence of reset button and its usage? Can you confirm that delivered mk808 is the same as offered on pictures from factory.
Thanks,
BooLE
leszcz
Re: Pictures of PCB
Postby leszcz » Mon Oct 01, 2012 7:18 pm
I wonder if those three pins above Rockchip could be serial console, as in UG802 :
http://eirev.blogspot.com/2012/09/oval-elephant-ug802-with-rk3066-cpu.html
Re: Pictures of PCB
Postby deadhp1 » Tue Oct 02, 2012 9:35 am
leszcz wrote:Hi,
They probably are. I had been thinking that those spots we're for serial console on the ug802 and those others on the mk808. I just lack the hardware to test them :( . I'm glad someone tested the pins on the ug802. I read through the log it was interesting.
jaapschaap
Re: Pictures of PCB
Postby jaapschaap » Wed Nov 21, 2012 3:52 pm
Alternative antenna system:
joahfitzgerald
Re: Pictures of PCB
Postby joahfitzgerald » Wed Nov 21, 2012 5:51 pm
Thank you for the outstanding pictures depicting the pins on the v2.
jaapschaap
Re: Pictures of PCB
Postby jaapschaap » Thu Nov 22, 2012 10:39 am
joahfitzgerald wrote:Thank you for the outstanding pictures depicting the pins on the v2.
No Problem!
I got even more if you need it:
https://picasaweb.google.com/1182678603 ... cLPye-wigE
