U2C Not working
bob54751
U2C Not working
Postby bob54751 » Fri Jul 26, 2013 2:27 pm
I recently picked up a U2C in Taipei along with the U2C-D dock. I connected everything as instructed and
connected the device to my HDMI port on the TV. When I power on the U2C I get no setup display on the TV.
All I see is 2 penguins and no signal detected. I get the same result on both HDMI inputs. Any suggestions?
bob54751
bitneak
Re: U2C Not working
Postby bitneak » Wed Jul 31, 2013 3:06 am
do you provide enough power fir this device? its recommanded a 5V 2A power supply~
Or maybe rom is broken, flash it with the finless rom 1.7 for measy u2c~
bob54751
Re: U2C Not working
Postby bob54751 » Fri Aug 02, 2013 2:16 pm
will have to check on the power supply, I know it was 5V, blv maybe amperage was 1.5A.
Don't see how I can flash it if I cannot get it working.
bob54751
Re: U2C Not working
Postby bob54751 » Sat Aug 03, 2013 4:28 pm
Went out and got myself 5V, 2A power supply and successfully got into the U2C.
What software do I need to install the new firmware if I want to use my ASUS TF201 (Android HC4.1) .
to connect to U2C,
bob54751
Re: U2C Not working
Postby bob54751 » Sat Aug 03, 2013 7:12 pm
Previous post should have read Android 4.1.1
Marco2015
Re: U2C Not working
Postby Marco2015 » Thu Dec 24, 2015 1:06 am
Hi:
My Measy U2C didn´t work.
I checked the input 5 V 2 Amp for the device and it was correct.
I tried to update the firmware with RKBatch tool-v1.5 but I couldn't.
I found a new RKBatch tool-v1.8 in internet:
http://www.mediafire.com/download/768dc ... l-v1.8.rar
I downloaded and unzip the file. After this, I upgraded the firmware succesfully.
I hope it helps someone.
Sincerely
Marco2015
Return to “Measy U2C”
