Measy U2C User's Manual
n3wb13
Postby n3wb13 » Tue Mar 19, 2013 1:36 pm
Here is the user's manual come in Measy U2C's package. It's scanned in 300dpi so it's a bit large.
Another safety instruction not in the manual is that: Once you have powered up the Android stick, you should NEVER touch the HDMI port with bare hands. I got quite an electric shock after accidentally touched the HDMI port when trying to unplug it to connect the AV cable to test output mode (NTSC or PAL) :!:
bitneak
Re: Measy U2C User's Manual
Postby bitneak » Wed Mar 20, 2013 10:12 pm
thank you n3wb13 for the manual!
Return to “Measy U2C”
