How To - Root CX-01
Stock and Custom Firmware Development For the CX-01.
tatubias
How To - Root CX-01
Postby tatubias » Mon Oct 29, 2012 11:20 am
Here are the instructions to root it:
note: a user hss reported that unlock root bring a malwared installed so be aware of this method. below is an other methot to do the rooting
Download Unlock Root http://www.unlockroot.com/. NB: The download link does not appear to work right now, but the filename is unlockroot23.exe, so here are some alternative untested download links.
Find Unlockroot\driver\android_winusb.inf in the directory where you install Unlockroot
Open the file in a text editor, and add the following lines:
For Win 7 (64-bit):
[Google.NTamd64] 64-bit]
;TCC8920
%SingleAdbInterface% = USB_Install, USB\Vid_18D1&Pid_DEED&MI_01
%CompositeAdbInterface% = USB_Install, USB\Vid_18D1&Pid_DEED&Rev_0231&MI_01
For WinXP (32-bit):
[Google.NTx86]
;TCC8920
Connect CX-01 to your PC via USB, it should then detect your new device. If it doesn’t simply press “fn” key on CX-01 TV Stick.
Select the driver that you edited in Unlockroot\driver\android_winusb.inf
Once the driver is installed, run unlockroot
Press ROOT, then reroot device.
Reboot CX-01 mini PC
Done!
Read more: http://www.cnx-software.com/category/processors/telechips-tcc89xx-tcc8900-tcc8902-tcc8925/#ixzz24E6Gia2j
