Why you choose VKWORLD VK6050 VKWORLD VK6050? Because of the
An announcement forum for our friends over at Geekbuying.com
Postby geekbuying » Wed Jun 24, 2015 4:33 am
Why you choose VKWORLD VK6050 VKWORLD VK6050? Because of the exemplary battery life
There are 4 reasons you have to choose it:
1.The VKWorld VK6050 comes with a massive 6050 mAh battery inside, which is said to go for even a week with light use, which translates to about 4 days of moderate use, which in turn means: awesome! Truth be told, we’re still in the early phases of testing this phone, so we can’t really promise that kind of battery life on it, but that massive battery combined with the specs of the phone is booming and promising, of course. The design of the phone is pretty neat and simple, and you might confuse it with Xiaomi phones, because it sports similarly thin bezels all around.
2.There are capacitative buttons on the front, and thin bezels on the side, in a polycarbonate body. Although there’s nothing special about its design, the company behind this battery life monster managed to keep the thickness of the device down at 0.95 mm, which is exemplary for a 6050 mAh battery-touting beast. Otherwise, I would put the VKWorld VK6050 in the mid-range category, based on its camera, performance and UI.
3.Note that the skin on the device is very similar to Sense, so that might be interesting to make use of. Specs wise, the phone comes with a massive 5.5 inch display that has a 720*1280 HD resolution. It comes with a 64 bit MTK6735 CPU, backed by 1 GB RAM and 16 GB internal storage, with a microSD card slot available for extra expansion.
4.A 13 MP camera with flash sits on the rear, while the front is decorated with a neat 5 MP selfie camera. It comes with Android 5.1 Lollipop on board, and it supports 4G.
As such, the VKWorld VK6050 might just be one of the best mid-rangers right now, and not just because of the exemplary battery life
Highlights
•5.5inch IPS OGS capacitive screen, 1280x720 pixels
•CPU:MTK6735 Quad Core, 1.0GHz GPU:Mali-T760
•Android 5.1 OS , 1GB RAM + 16GB ROM
•Dual SIM card dual standby, 6050mAh battery
•Dual Cameras, 5.0MP front camera, 13.0MP back camera with flashlight and auto focus
•Support FDD LTE/4G/3G/GPS/Wifi/Bluetooth
•Networking:2G: GSM 850/900/1800/1900MHz, 3GWCDMA 850/900/2100MHz, 4G: FDD LTE: 800/1800/2100/2600MHz
See More Details here!!!
Return to “www.geekbuying.com”
