[FIRMWARE] STOCK 20130125-kernel 20130129-fix static on AC3
woofe2r
Postby woofe2r » Fri Feb 01, 2013 2:12 pm
THE FIRMWARE IS PRE-ROOTED!!! NO ROOT PROCEDURE NEEDED:)
"Hi Guys:
Tronsmart just made a new upgrade for their Prometheus, they fixed the problem with the static on AC3 audio tracks.
here are the firmware download links:
1.https://www.dropbox.com/s/lnckzfukfjzlrhk/2013-1-29rootac3.zip?m - original download link
2.http://d-h.st/nu8 - mirror download link
Upgrade method:
1. Open the download folder;
2. you will get below 5 files.
3. Put these 5 files (don’t open zip file) in root of your SD card, then follow below upgrading method,
(1) Use a paperclip inserts to press the reset key which is at back side of the Android TV Box and hold it;
(2) Power on the Android TV Box (connect the AD adapter with device), wait for blue Led flash 3 times then release reset key;
(3) System will automatically upgrade. (Make sure power is not interrupted during the upgrading process);
(4) Device will be reboot after upgrading. (Check the software version in setting-> about media player. You will see it)."
ANTUTU SCORE: Overall 7547, CPU 3421, GPU 1908, RAM 1444, I/O 801, 1320MHz (x2) [1280x672], (Output mode set to 1080p 60hz).
Overall score depends on inserted SD-CARD(speed I/O) and may be different.
Tested on 32Gb class 10 GoodRAM sdcard.
rhepungus
Re: [FIRMWARE] STOCK 20130125-kernel 20130129-fix static on
Postby rhepungus » Sat Feb 02, 2013 1:32 am
Just ordered mine from Geekbuying. Looking forward to this...thanks!
math1203
Postby math1203 » Sat Feb 02, 2013 12:26 pm
Now only full XBMC-support and DTS-sound is missing from perfection :)
shharper
Postby shharper » Sun Feb 03, 2013 12:07 pm
Aeems like Dropbox has cut off downloads -- too much bandwidth being used. Please post the firmware somewhere else.
woofe2r
Re: Odp: [FIRMWARE] STOCK 20130125-kernel 20130129-fix stati
Postby woofe2r » Sun Feb 03, 2013 12:57 pm
shharper wrote:Aeems like Dropbox has cut off downloads -- too much bandwidth being used. Please post the firmware somewhere else.
There are two download links.
See the first post and look for the second link again:)
«««««Tapatalked from: MK808, Tronsmart Prometheus, SGS, SGS2»»»»»
shharper
Postby shharper » Mon Feb 04, 2013 11:37 am
Thanks!!
