[FIRMWARE] STOCK 20121215 - kernel 20121227
woofe2r
Postby woofe2r » Sat Jan 12, 2013 8:21 am
[THE DESCRIPTION BELOW IS FROM BLOG.GEEKBUYING, IT'S NOT MINE!!!]
Hi guys:
We just get the stock firmware for Tronsmart Prometheus Amlogic m6 dual core tv box, here is the firmware download link:
http://www.sendspace.com/file/e0ru4m
here is the firmware update instruction:
1 Download firmware from the above link;
2 Decompress the file, and you will get 4 files
3 Put these 4 files(don’t open zip file) in root of your SD card, Use a paperclip inserts to press the reset key which is at back side of the Android TV Box and hold it.
4 Power on the Android TV Box (connect the AD adapter with device), wait for blue Led flash 3 times then release reset key.
5 System will automatically upgrade.( Make sure power is not interrupted during the upgrading process.
6 After 3-5 mins, device will be reboot after upgrading .(Check the software version in setting-> about media player. You will see it).
We have tested with this method, and everything is right, here is the screenshot after we upgrade successful:
Enjoy the Firmware, any suggestions, feel free to ask.
Update 4th Jan, we take a video for how to update firmware, check here:
http://www.youtube.com/watch?v=L875_YLSIGI
DIRECT LINK AND MORE INFO -> http://blog.geekbuying.com/index.php/2013/01/02/stock-firmware-for-tronsmart-prometheus-download-and-instruction/
ANTUTU SCORE: Overall 7564, CPU 3508, GPU 1786, RAM 1464, I/O 806, 1320MHz (x2) [1280x672], (Output mode set to 1080p 60hz).
Overall score depends on inserted SD-CARD(speed I/O) and may be diferent, for example without it overall score was 7986.
Tested on 32Gb class 10 GoodRAM sdcard.
