lots of modules and firmwares, and new kernels
KIZS
Postby KIZS » Sat Dec 15, 2012 2:38 pm
2013.01.04:
I made new kernel last night, here it is:
1920x1080:
http://dl.dropbox.com/u/44128030/kizs_kernel_v4_1080.img
1280x720:
http://dl.dropbox.com/u/44128030/kizs_kernel_v4_720.img
720x480:
http://dl.dropbox.com/u/44128030/kizs_kernel_v4_480.img
Be carefully and check the warming!
2012.12.15:
Many people write me, "Please compile blabla driver for me for my blabla gadget what I'd like to use with mk808."
So, I built scores of drivers and shared for you...
Modules:
http://dl.dropbox.com/u/44128030/kizs_modules.tgz
Firmwares (without any modification from git://git.kernel.org/pub/scm/linux/kern ... rmware.git):
http://dl.dropbox.com/u/44128030/linux_firmwares.tgz
And kernels (it's new, I think faster than previous version):
http://dl.dropbox.com/u/44128030/kizs_kernel_v2_1.5GHz_720.img
http://dl.dropbox.com/u/44128030/kizs_kernel_v2_1.5GHz_1080.img
Use it and be happy.
And a question at last: how can I use my Trust mini BT USB dongle (17772, AR3011 chipset) with android on mk808?
My kernel recognize it, the blue led light, but Android doesn't use it.
I see in log:
<6>[ 200.906632] Bluetooth: Atheros AR30xx firmware driver ver 1.0
<6>[ 201.215256] usbcore: registered new interface driver ath3k
<6>[ 201.380411] usb 2-1.3: USB disconnect, device number 3
<6>[ 202.641713] usb 2-1.3: new full speed USB device number 5 using usb20_host
<6>[ 202.763129] usb 2-1.3: New USB device found, idVendor=0cf3, idProduct=3005
<6>[ 202.770058] usb 2-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
<6>[ 223.761408] [BT_RFKILL]: bt turn on power
<6>[ 234.303334] [BT_RFKILL]: bt shut off power
Re: lots of modules and firmwares, and new kernels
Postby lewy20041 » Sun Dec 16, 2012 6:30 pm
thx foryour work. but sadly this karnel dont suport usb to ethernet adapter the previous one did. whoud you mind kompile ith with usb to ethernet?
cmgmx
Postby cmgmx » Sun Dec 16, 2012 11:57 pm
Thks
Finless 1.5A Custom ROM + kizs_kernel_v2_1.5GHz_1080 sooo goood !!
Warlord1981
Postby Warlord1981 » Mon Dec 17, 2012 3:08 am
anyone else confirm usb2ethernet support?
wahhh
Postby wahhh » Mon Dec 17, 2012 7:53 am
AX88772B based USB-RJ45 adapter does not work with the new kernel(1080).
Sequ
Postby Sequ » Tue Dec 18, 2012 9:01 am
Wow. This V2 kernel is pretty much faster in my opinion than the original which come with finless 1.5a. And wifi working just fine. Good work.
bayliner195
Postby bayliner195 » Tue Dec 18, 2012 11:52 am
Szia Kizs,
Ezzel a v2 kernellel megoldódott a wifi eldobás probléma?
Vagy ajánlod vmelyik antenna mod-ot? :mrgreen:
KIZS
Postby KIZS » Tue Dec 18, 2012 4:05 pm
bayliner195 wrote:Szia Kizs,
Szia!
A kernel maga nem oldja meg a wifi gyengeségét, de tapasztalataim szerint az itt ajánlott rk901.txt-vel tényleg egészen jó lesz:
http://armtvtech.com/armtvtechforum/viewtopic.php?f=66&t=212&start=360&sid=ce28fbad99753959cc96d58957cd3a28&sid=709233f8db5726b34c6e81cc9db835c9#p5456
Ha megnézed a prohardver.hu-n az mk808 forumot, akkor ott találhatsz egy általam kicsit módosított Finless féle rom-ot amibe ez a wifi firmware van belegyógyítva.
Szerintem az és valamelyik V2-es kernel már kifejezetten élvezetessé teszi a kütyüt.
in english:
So, this kernel doesn't solve the wifi problem, but I think the new rk901.txt much better than original. From here:
hegg
Postby hegg » Tue Dec 18, 2012 4:17 pm
Pretty happy with it, does not get trough antutu, but videperformance is by far the best yet. But I have lost the possibility to hook it up to a dac via usb. Is this something you would consider patching in?
fruitsalad
Postby fruitsalad » Wed Dec 19, 2012 3:34 am
I also tried a lot of kernels and firmwares here. But i have to say the only configuration that works for me is finless rom 1.5a.
In every other combination i have major problems with lagging and buffering in sopcast. As if the wifi connection drops very often and the buffer goes down.
Wish there was a firmware with 1080ß, stable wifi and no problems with sopcast. I use sopcast 9.0 and i have the v2 hardware layout of mk808.
Are there any news from geekbuying whos sells this product??
muratremix
Postby muratremix » Fri Dec 21, 2012 10:07 am
I have a MK808 and I can't find info regarding how to change Kernel on a custom rom like finless or others.
I understand kernel has to change if we want to switch from 1080p to 720p screen.
Btw 1080p is very sluggish on MK808, although MX player can play some 1080p mkv files without any problem, it doesn't work good with most of them. Without smooth 1080p mkv playback, 1080p screen mode loses all its incentive.
julandroid
Postby julandroid » Fri Dec 21, 2012 9:31 pm
Today I've flashed the 720p kernel version, but unfortunately I've immediately noticed problem with the USB sound.
I'm using Finless Bob 1.5a ROM and everything worked well before I've tried the new kernel.
The usb device is recognized according to the dmesg, but it is not registered in the GUI (android settings app). If I open the Sound tab and after that sound manager, the only listed sound device is the build-in HDMI one.
Another issue (I assume related) that I've noticed was the issue with selecting the usb mode (Settings -> Storage). Every time I tick some of the options like Mass storage or any other, the tick persist and at the end I have all selected usb modes simultaneously checked!
At the end I had to revert the kernel to the original one.
julandroid
Postby julandroid » Fri Dec 21, 2012 9:37 pm
muratremix wrote:I have a MK808 and I can't find info regarding how to change Kernel on a custom rom like finless or others.
If you download the Finless rom, inside the zip file you will find everything needed to flash the rom. By default, when you run the flashing app, all parts of the rom are preselected. If you need just to flash the kernel, then you need to unselect all other parts (like boot.img, recovery.img, etc) and leave only the kernel's tick. Of course you have to change the path to your kernel image. Be aware, that every image (boot, kernel, recovery...etc) has offset and maximum size, so you have to be sure (in your particular case) that the kernel image is not longer the maximum, otherwise it will overwrite the next image in the chain.
muratremix
Postby muratremix » Sat Dec 22, 2012 8:16 am
After flashing Finless 1.5A using RKAndroidTool, everything was easy.
Now I can also run Ubuntu 0.3 on it. Finless 1.5A is very smooth on 720p aswell.
LukC
Postby LukC » Sat Dec 22, 2012 8:26 am
Hi KIZS, thx for the kernels but I wanted to ask if you could add Camera support to the kernel. The standard ones run my Logitech C270 without any problems.
thamichie
Postby thamichie » Sat Dec 22, 2012 11:19 am
Could you do a 1.7Ghz version as well ? :)
julandroid
Postby julandroid » Sun Dec 23, 2012 7:55 am
KIZS, any feedback regarding issues with the USB mentioned above?
jaciga
Postby jaciga » Sun Dec 23, 2012 8:21 am
could anyone please compile also the usbserial.ko module?
