DVB-T support
bay
DVB-T support
Postby bay » Fri Dec 14, 2012 3:41 pm
Interested by DVB-T , could get af9015 based, and one other (siano)
usb adapters running.
http://linuxtv.org/wiki/index.php/DVB-T_USB_Devices
Have a rooted system,
with "Root Explorer" installed (or know how, using shell)
Take attachement.
Create a /system/modules folder
put "/modules/media" folder at /system/modules/media
Or other place but you have to reedit "setup-dvb" content
Put "firmware" files under /etc/firmware
Put "setup-dvb" under /system/xbin with right permissions ("execute" rights).
get DVB-T application, and install:
File droidtv.apk found under folder: droidtv/market/
from https://github.com/Elbandi/droidtv /version with external player try MxPlayer or Vplayer
or https://github.com/chrulri/droidtv
(or compile version you are interested from "network" branches )
Connect DVB-T Stick.
Open a terminal
Type: su /to get root privileges
Type: setup-dvb / to load modules and create folders, links in /dev
Alternativly for experts: copy the content of "setup-dvb" in file /etc/install-recovery.sh (create the file if needed) to have the system setup during boot.
Type: lsmod /to check that modules have been loaded
Type: dmesg /to check that af9015 based stick (or siano) is recognised, the firmware is loaded,..
You can also check that /dev/dvb0.dvr0 interface is created as consequence of stick recognition.
Run tv application and enjoy it .
inovaxt
Re: DVB-T support
Postby inovaxt » Sun Dec 16, 2012 8:28 am
Thanks for your efforts, I am the new comer, could you kindly show me how to
1. run "setup-dvb"?
2. There are many files inside DVB-T application, where do I put those in the MK808?
Thanks again.
enviro8
Re: DVB-T support
Postby enviro8 » Tue Dec 18, 2012 3:10 am
inovaxt wrote:Thanks for your efforts, I am the new comer, could you kindly show me how to
1. run "setup-dvb"?
Thanks again.
I too am having a lot of trouble setting this up.
When I run setup-dvb I just get a whole lot of permission errors.
A bit more info would be greatly appreciated.
bay
Re: DVB-T support
Postby bay » Tue Dec 18, 2012 2:49 pm
You have to have root enabled.
Using "Root Explorer" application put
Drivers in:
/system/modules/media/
Firmware files in:
/etc/firmware
"setup-dvb" file in:
/system/xbin /with execute enabled
Go in terminal
Type: su / to get root permissions
Type: setup-dvb / to load modules and create folders in /dev
then run DVB-T application…..
inovaxt
Re: DVB-T support
Postby inovaxt » Tue Dec 18, 2012 8:38 pm
Thanks for help, how to run DVB-T application? Many files inside this DVB-T application zip, could you show us how to run it?
Thanks :D
bay
Re: DVB-T support
Postby bay » Wed Dec 19, 2012 8:56 am
See notes updated on top ;-)
saman
Re: DVB-T support
Postby saman » Thu Dec 20, 2012 9:39 am
Hi
super guide
udp streaming works, but how do I play, the vlc "udp://127.0.0.1:1555" does not work
jerrylee
Re: DVB-T support
Postby jerrylee » Thu Dec 20, 2012 11:25 pm
Thanks Bay
I got a DVB-T stick yesterday and kind make it work by follow your guide. Thanks a again.
it did get scan channel works, however when I choose any of them to watch. none of them is working (all in black screen), and crash back to desktop sometime.
Another other suggest DVB-T app will be appreciated.
saman
Re: DVB-T support
Postby saman » Fri Dec 21, 2012 5:31 am
jerrylee wrote:Thanks Bay
This program is merely a stream server (DVBlast), you must use some other player for video playback, for example vlc, but unfortunately I do not know the exact syntax.
Server sends the stream to 127.0.0.1:1555.
bay
Re: DVB-T support
Postby bay » Fri Dec 21, 2012 1:17 pm
See update on top. have added compiled version of app with external player
saman
Re: DVB-T support
Postby saman » Fri Dec 21, 2012 1:30 pm
Thanx, I try it.
bay wrote:See update on top. have added compiled version of app with external player
wiki
Re: DVB-T support
Postby wiki » Fri Jan 04, 2013 9:37 am
I keep getting "unable to chmod dev/dvb/adapter0/demux0: no such file or directory"
What am I doing wrong?
bay
Re: DVB-T support
Postby bay » Sat Jan 05, 2013 6:19 pm
It looks that some kernels does not have the right setup eg latest KIZS kernel trigger this message.
However you can use the nice stable kernel in the following link:
viewtopic.php?f=13&t=718&start=60#p4512
Cheers,
chrishoughton
Re: DVB-T support
Postby chrishoughton » Sun Jan 06, 2013 3:43 pm
Same problem with either that kernel or the default Finless Bob 1.6 kernel. Any ideas?
Has anyone tried this with a Playstation 3 Play TV?
wiki
Re: DVB-T support
Postby wiki » Thu Jan 10, 2013 9:00 am
bay wrote:It looks that some kernels does not have the right setup eg latest KIZS kernel trigger this message.
Cheers,
Thanks,
how can I change kernel?
I know how to flush a new ROM, but kernel?
complete
Re: DVB-T support
Postby complete » Sat Jan 26, 2013 9:17 am
wiki wrote:Hi,
I have the same problem, you know any solution?
bay
Re: DVB-T support
Postby bay » Sat Jan 26, 2013 7:19 pm
Top message has been updated:
make sure you connect dvb-t stick 1st before typing "setup-dvb"
and check that it is recognized and firmware loaded typing "dmesg" in terminal.
For people having "special" fw you can use the nice stable kernel from KIZS in the following link:
Using method documented at:
viewtopic.php?f=13&t=718&start=70#p4639
xboxhacker
Re: DVB-T support
Postby xboxhacker » Wed Jan 30, 2013 5:49 pm
What are the odds of this working for ATSC North America DVB????
chrishoughton
Re: DVB-T support
Postby chrishoughton » Thu Jan 31, 2013 2:50 pm
I'd love to test this. Can anyone recommend a cheap USB DVB-T tuner?
bay
Re: DVB-T support
Postby bay » Sat Feb 02, 2013 6:16 pm
Over and above af9015 there is also siano modules in the zip file:
and the following stick is cost effective and works, while having a bit les sensitivity than some others:
http://www.nikingstore.com/shop/geniate ... e-463.html
NB: I do not have any interest, this is just an example.
You can also see af9015 based devices: http://www.linuxtv.org/wiki/index.php/Afatech_AF9015
eg AVerTV Volar Black HD (A850).
