!NEW! MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
magpte
Re: !NEW! MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.20
Postby magpte » Sun May 26, 2013 10:24 pm
I am just a light user of mk808, i dont know how to compile a wlan driver, i have a rtl8187l, but i cant use it, can anyone compile or post one up here? It would do me great favour of it, thx in advance.
noregret
Postby noregret » Mon May 27, 2013 12:27 pm
which file in 2.2.2+ image is camera driver module?
with 2.1.2, 1080p video can be played smoothly without any choke, but with 2.2.3, it can not play 1080p smoothly.
but in 2.1.2, the camera driver seems to have problem, after close a video chatting session, the camera cannot be brought up again.
while 2.2.3 does not have this issue.
is there any way to migrate camera driver in 2.2.3 to 2.1.2?
alshark
Postby alshark » Tue Jun 04, 2013 5:52 am
Is it me or firmware links are dead?
Download stops after few MB are downloaded.
Postby lewy20041 » Wed Jun 05, 2013 12:57 am
all links are ok.
Postby lewy20041 » Wed Jun 26, 2013 1:53 am
NFS (Test) Kernel in first post.
mackowiakp
Postby mackowiakp » Wed Jun 26, 2013 2:25 am
I use 2.2.3 stable version on my MK808. The problem is, that from time to time, external wired Ethernet port does not start. Turning off/on from menu or unplug/plug eth USB module resolve the problem. Is any possibility (kid of script) to reload, turning off/on eth module several seconds after MK808 boot? It would be workaround for my situation. Any other idea?
Postby lewy20041 » Wed Jun 26, 2013 4:51 am
something like:
ifconfig eth0 down
ifconfig eth0 up
or
busybox ifconfig eth0 down
busybox ifconfig eth0 up
Put that code in init.d script or edit install-recovery.sh
Remember about permisions!
"rwx --- ---" for install-recovery.sh
"rwx r-x r-x" for init.d
mackowiakp
Postby mackowiakp » Fri Jun 28, 2013 2:08 am
I am looking for screensaver application for MK808 (not lockscreen!). It is because my MK808 is connected to plasma TV so I want to safe screen from burning out pixels during inactivity. The best would be black screen with clock moving around screen, similar to scrensavers available on ordinary PC.
Of course such screensaver should not turn on itself during watching long film for example.
There is a lot clock apps but dedicated for lockscreen not to cats as screensaver.
Does anybody know such good apps?
Valter84
Postby Valter84 » Fri Jul 05, 2013 12:26 pm
Hello lewy20041!
First, thank you for your great work!
I love your roms!
Do you know when we will get HDMI passthrough?
Also, I have a MK808B, do you know when we will have a overclocked 1080p kernel available?
The major problem I have on this mini cpu is that I can`t set xbmc properly on 1080p kernel to see my videos without lag! :S
With 720p kernel, and XBMC XAF everything runs smooth but i have a 51` plasma tv, so i can see the diference from 720p and 1080p and I would love to be able to get xbmc wunning the same way with 1080p kernel.
All my videos are located in externel hard drive, connected to the MK808B. Is it possible with the actual firmware to watch movies on xbmc with the 1080p kernel? If yes, can you give me some guides how to?
Thank you for your help!
Postby lewy20041 » Sat Jul 06, 2013 4:45 am
i dont think there will be mk808b oveclocke kernel:"
everyone are working on rk3188 devices.
the best thing you can do is to get mk808 overclocked kernel and good usb to ethernet adapter:"
T68
Postby T68 » Tue Jul 16, 2013 6:04 am
Hi!
Just to check does this kernel support NFS on the mk808?
Postby lewy20041 » Wed Jul 17, 2013 11:40 am
yes it should,
its have nfs module.
shooter54
Postby shooter54 » Wed Jul 17, 2013 12:01 pm
hey... i have a Problem. when i scroll with the mouse in the Stock browser my tv screen gets flicker black and green........
freefourlife
Postby freefourlife » Thu Jul 18, 2013 11:03 am
Sleep is acting weird. When I click on sleep, it switches the blue light off and is available to come back up for a few mins with mouse/HID remote, but after about 10 mins, it wont wakeup, but has to be plugged out and in.
My mk808 is on this rom with 2dark4u kernel.
Is this an issue in this version of the ROM or minix versions from lewy?
Or is this the behavior with all the mk808s?
Please help.
Postby lewy20041 » Sat Jul 20, 2013 11:02 am
shooter54 wrote:hey... i have a Problem. when i scroll with the mouse in the Stock browser my tv screen gets flicker black and green........
disable screan overlay in debuging settings
Postby lewy20041 » Sat Jul 20, 2013 11:03 am
freefourlife wrote:Sleep is acting weird. When I click on sleep, it switches the blue light off and is available to come back up for a few mins with mouse/HID remote, but after about 10 mins, it wont wakeup, but has to be plugged out and in.
Please help.
its normal if there is no wifi or similar activity.
just check olways on in debuging settings
Tim91
Postby Tim91 » Sat Jul 20, 2013 12:26 pm
/I have an issue with mine waking up , operating normally for a few seconds then crashing. Has this happened to anyone else
shooter54
Postby shooter54 » Sun Jul 21, 2013 9:27 am
not working for me :?:
funt12
Postby funt12 » Wed Jul 31, 2013 7:35 am
Hi lewy20041!
Are you planning to make new version of this rom, because apparently minix has released new version for neo x5. It's not available on official minix website but it seems like geekbuying already have it.
http://blog.geekbuying.com/index.php/20 ... eekbuying/
Postby lewy20041 » Wed Jul 31, 2013 11:53 am
i would gladly do it but my mk808 went swiming and i dont have any rk3066 device.
maby in near future i will get one and then i will port it for sure.
