!NEW! MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
stantheboss
Re: !NEW! MK808/MK808B/MINIX Hybryd FW V2.2.3 !NEW!(01.05.20
Postby stantheboss » Fri May 03, 2013 4:31 pm
Does V2.2.3 for MK808 1080p still suffers from limited CPU clock rate? Android tuner reports 1008Mhz as max frequency!
sebcbien3182
Postby sebcbien3182 » Sat May 04, 2013 5:18 am
Hi
Thanks for your job. It's very great.
I use your firmware on my MK806. But the only problem is that the audio jack don't work and not appear in the audio system in system setting.
Can you add this functionnality ? Is it possible ?
Thanks to your answer. Excuse my bad english, i'm french.
Sébastien
puroc
Postby puroc » Sun May 05, 2013 11:00 pm
I have an MK808 with an antenna mod. The best speedtest.net scores are still on the Hybryd 2.1.1 1080 rom at 15032kbps down and 2062kbps up. Non of the other firmwares including Finless1.7c( which only got about 700kbps up and down) and Hybryd 2.2.3 (which got about 2000 down and 1000kbps up) come close to 2.1.1.
I live in an apartment where there is lots of wifi interference and the router is behind 2 walls.
I am sticking with this one for now. If you are having alot of problems with WIFI speeds try going back to 2.1.1.
stantheboss
Postby stantheboss » Sat May 11, 2013 1:06 pm
How do I flash 2dark4u kernel alone without reflashing the whole rom? There's no build in recovery so I assume it is done through some king of flasher...
Postby lewy20041 » Sun May 12, 2013 1:19 am
use finless tools.
just download 1 of his rom and you will have flasher.
yodvav
Postby yodvav » Thu May 16, 2013 12:40 am
Hey Lewy
I was in Finless 2.0 beta, then i flashed your rom. Its all great so far, but somehow usb storage is not working anymore. I enable usb debuging and conect to PC, and nothing..
The usb icon on the notification area never appears to enable usb storage.
What could be the problem?
Postby lewy20041 » Thu May 16, 2013 3:05 am
you need to add mass_storage to build.prop.
i will put this in next ver.
yodvav
Postby yodvav » Thu May 16, 2013 10:30 am
Hi Lewy
Thanks! That worked perfectly. Thanks for the quick response.
I am very satisfied with your rom.
I am very interested in the users function on the JB 4.2.2
Any release dates for your next build? (:
Postby lewy20041 » Thu May 16, 2013 2:29 pm
the next one still will be 4.1.1 i alredy have done moust bug fixs, cosmetiks and etc. but i dont have much time now to publish it.
i will work on 4.2.2 after this relese i also will try to compile some modules for 3.0.36 kernel which is presented in 4.2.2 thanks to published sources.
yodvav
Postby yodvav » Thu May 16, 2013 4:28 pm
Lewy, one more thing
I actually flashed your rom because i want to play games with a Xbox 360 Controller using the xpad.ko you added to the rom start up.
But when i connect the controller to the mini pc, nothing happens and i cant even control the launcher and such.
What should i do to make it work?
Postby lewy20041 » Fri May 17, 2013 2:51 am
is this original xbox controler?
it shoud work:"
in terminal app write:
su
lsmod
check if xpad module was loaded.
yodvav
Postby yodvav » Fri May 17, 2013 4:17 pm
Yes it is an original xbox controller.
I tried lsmod and it changed nothing. I tried with several games.
But anyway, im giving up already.
Postby lewy20041 » Sat May 18, 2013 1:04 am
lsmod not insmod.
i need to know if xbox.ko was properly loaded.
yodvav
Postby yodvav » Sat May 18, 2013 10:16 am
Thats what i said, lsmod.
How do i know if it was properly loaded?
I assume that it was because arctools recognizes it as an xbox 360 driver.
Postby lewy20041 » Sun May 19, 2013 2:48 am
vhen you type lsmod in terminal app you will get a list of loaded modules.
check if xpad.ko is there.
mo123
Postby mo123 » Mon May 20, 2013 6:13 am
Lewy20041, Can you make a new rom for mk808/B from Minix NEO X5(20130520, version 011) firmware released today?
Postby lewy20041 » Tue May 21, 2013 11:52 am
i will relise 4.1.1 ver based on latest minix firmware today.
and as a bonus beta of minixhfw android 4.2.2 but keep in mind that it will have much less futures tnhe 4.1
vasanthtcs
Re: !NEW! MK808/MK808B/MINIX Hybryd FW V2.2.0 !NEW!(13.04.20
Postby vasanthtcs » Tue May 21, 2013 12:27 pm
lewy20041 wrote:yap. there is a problem with nfs module. for now if you want to use nfs try xbmc.
it have native nfs suport.
i tryed nfs on xbmc and its working nice.
busybox isnt mounting the nfs share.
i will try my best to make it working in next relise.
Hi lewy ... Any luck with this yet ? :)
Postby lewy20041 » Tue May 21, 2013 2:13 pm
nope. minix added the nfs module to the kernel so no go for now:"
i wont make to upload new ver today.
i will do it tomorow.
vasanthtcs
Postby vasanthtcs » Tue May 21, 2013 5:06 pm
lewy20041 wrote:nope. minix added the nfs module to the kernel so no go for now:"
Ok thanks for the update .. :)
Users browsing this forum: Yahoo [Bot] and 1 guest
