!NEW! MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
saperos
Re: !NEW! MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.20
Postby saperos » Mon Sep 30, 2013 5:15 pm
Hello lewy20041 / Cześć :)
I bought THIS on our local site and I can't get it to work :(
- it is based on RT5370 chipset, which (as description says) is supported by default...
Unfortunately I have great problems with it. I have installed MK808_MinixHFW_2.2.3_1080p.img + Additional Content Installer 1.3 All.rar
Did test with wifi card connected to normal USB and to OTG port, no luck it is not blinking its light.
(i plugged it, turned on wifi / plugged, restarted device and turned wifi, lots of combinations - nothing work)
Then I renamed rkwifi.ko to tkwifiOLDko and rt5370sta.ko to rkwifi.ko.
From This moment when i am trying to turn on wifi it turns off automatically... :(
This I also tested on normal and OTG ports.
I would greatly appreciate your help as my internal wifi is very, very weak and works well for minute or two.
PS. With my PC this usb wifi card work perfectly fine
BR,
Kuba
lewy20041
Postby lewy20041 » Tue Oct 01, 2013 2:18 am
did you changed permisions when you renamed rkwifi.ko?
it should be "644" "rw- r-- r--"
Everything is possible if we work together!
stantheboss
Postby stantheboss » Fri Oct 11, 2013 3:43 pm
Does it work? I mean after setting correct permitions. If it does, I'd buy one.
stantheboss
Postby stantheboss » Wed Nov 20, 2013 5:26 am
Hi guys, need some helf on this one.
Got myself a TP-LINK TL-WN723N V3 wifi usb dongle which comes with realtek RTL8188eu chipset on board.
My mk808 is flashed with V2.2.3 1080p rom, kernel - 2dark4u 1.4 1080p.
Tried to overwrite /system/lib/modules/rkwifi.ko with 8188eu.ko which was already inside modules dir, but no luck, wifi won't turn on. Can anybody guide me how do I compile the driver using that https://github.com/lwfinger/rtl8188eu zipped source ? Cannot find binaries like MAKE to be able to do so... or maybe there's another way to get this working?!
scooter
Postby scooter » Mon Feb 23, 2015 3:19 pm
Hi guys,
can you make a .ko for Wifi stick RTL8188SU ?
http://www.realtek.com.tw/DOWNLOADS/dow ... loads=true
Thanks in advance
cimbike
Re: !NEW! MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
Postby cimbike » Thu Feb 04, 2016 7:19 am
I have MK808 and I'm on finless rom but I'd really like to try out this one.
The problem I've got is that when I connect the MK to my laptop it's not recognized by the RockChipBatch Tool but it's recognized by the finless Rom_Flash_Tool.137.
I tried changing drivers for the ones attached but with no luck. I also tried using and old laptop with win xp but not luck whatsoever.
My question is, as my laptop does recognize my MK using finless Rom_Flash_Tool, can I flash this rom using this tool? and If so, should I just check option 8 buckup image and uncheck the rest?
I'd much appreciate any help.
Users browsing this forum: Bing [Bot] and 2 guests
