Q: External SD mounted as internal
szantinge
Postby szantinge » Tue Dec 04, 2012 5:59 pm
Hello Users,
Would it be possible to make a rom where the complete internal flash memory would be mounted as system partition and mount the external SD as the internal?
I have an 32GB micro SD and I thought this would make it better, because the bigger room to install apps and stuff.
Greetz
jorgen41
Re: Q: External SD mounted as internal
Postby jorgen41 » Fri Dec 07, 2012 11:01 am
You could try this one if i understand you correcly..
http://forum.xda-developers.com/showthr ... ?t=2022727
