Paranoid Android for MK808
ondiego
Postby ondiego » Mon Dec 03, 2012 2:28 pm
Hello, I'm searching Paranoid Android to MK808
CyanogenMod 10, already has a ROM on http://cm3066.com/
WAI
Re: Paranoid Android for MK808
Postby WAI » Mon Dec 03, 2012 8:07 pm
Thanks, i shall try this out soon. will post back
norcal618
Postby norcal618 » Tue Dec 04, 2012 2:10 am
What are the instructions for flashing cyanogenmod on the mk808?
WAI
Postby WAI » Tue Dec 04, 2012 5:49 pm
you have to flash with rkbatchtool
evildave_666
Postby evildave_666 » Tue Dec 04, 2012 6:46 pm
I did not have any success loading this firmware.
Used rkbatchtool 1.5, same version I've used to successfully flash a rk3066 tablet. No particular issues during the flash process (sane information in the info fields after selecting the .img file, logs looked like a successful flash), except afterwards the stick is stuck in flash mode and won't exit, even after power unplug/replug.
Subsequently flashed back to my previous firmware without incident.
antieco
Postby antieco » Thu Dec 06, 2012 6:17 pm
Downloading..
BTW the file flash.img should be flashed renamed to system.img?
evildave_666
Postby evildave_666 » Thu Dec 06, 2012 8:24 pm
It appears to be a fully packed firmware (multipartition) for rkbatchtool.
antieco
Postby antieco » Thu Dec 06, 2012 8:36 pm
upgrade or restore¿?
evildave_666
Postby evildave_666 » Fri Dec 07, 2012 12:50 am
It should be restore, but as I said before, it doesn't leave the stick in a usable state. It permanently comes up in flashmode, even after a power cycle. I will try going to the 4.1 CM10 this weekend, then wiping and installing the .zip version via recovery.
antieco
Postby antieco » Tue Dec 11, 2012 6:48 pm
Thanks, Ill be waiting for your test.
cheers
sainiboyz123
Postby sainiboyz123 » Wed Jan 23, 2013 10:42 am
After boot screen there is nothing screen is getting blank nothing showing..... :(
