1080p Firmwares!
fliegergott
Re: 1080p Firmwares!
Postby fliegergott » Wed Nov 28, 2012 3:29 pm
Hi!
I´m new here and did already tried some firmwares.
After updating to mk808_1416mhz_1080p the Rockchip-Batchtool 1.5 is not connecting.
What is going wrong? Is it the new kernel?
Pleas help me!
Thx, Gunter
genny
Postby genny » Wed Nov 28, 2012 3:50 pm
for all:
i tested the mk808, mk802 III, UG802 and MInix Neo G4. all with rk3066 cpu
The only good device for for assembling hardware and firmware is the Minix Neo G4
UG802 and MK802 III have a wifi module buggy and not solvable in my opinion
the mk808 with a good firmware is acceptable.
the minix neo g4 is well like a galaxy s 2. very good device
look all forums on internet and see how many complain about UG802 and MK802 III. ATTENTION
Postby deadhp1 » Wed Nov 28, 2012 3:55 pm
fliegergott wrote:Hi!
Pleas help me!
Thx, Gunter
I haven't had that issue at all.
I do ALOT of firmware flashing.
I've tested by 3 methods to get rockchip batch tools to see the mk808 and they all work.
(first plug into otg usb port)
Method 1)
Install terminal emulator and type:
su
reboot bootloader
Method 2)
a)Go into Settings---Developer options---make sure usb debugging is disabled
b)Settings--->Storage--->Click the 3 vertical dot icon in the upper right corner-->Click USB computer connection--->Check the box for mass storage
c)Settings--->USB--->Connect to PC
d)In rockchip tools you should see a pink icon, now you can click the switch button to make the icon go green for flashing.
Method 3)
Using a paperclip or pin press the hidden reset button while plugging in the mk808.
Postby deadhp1 » Wed Nov 28, 2012 4:05 pm
genny wrote:for all:
Minix was supposed to send me a sample of the Neo G4. It hasn't turned up, and I've not heard back from them.
I'm sure the Neo G4 is a nice device, I'd love to have one to work on.
The UG802 1080p rom I posted might work on the Neo G4. I just can't test it, and wouldn't until a firmware update is released.
The Neo G4 uses the SAME wifi module as the UG802 and MK802 III.(max speed 150mbps)
MK808 uses rk901(max speed 65mbps)
Let's keep this thread for those who have the MK808.
contruk27
Postby contruk27 » Wed Nov 28, 2012 4:28 pm
Hi!
For those who find the fonts and the icons too small, just change the lcd_density at build.prop from 160 to 220. Everything will be as big as before! :D
Dero
Postby Dero » Wed Nov 28, 2012 4:48 pm
Hi, this firmware is built from the "leaked" kernel sources, right?
So, we don't know if there is something still "hidden" from us in the stock kernel?
dero
salundy
Postby salundy » Wed Nov 28, 2012 5:27 pm
Thanks deadhp1 for your great work. ;-)
Does it contain Root and SuperUser?
Dero
Postby Dero » Wed Nov 28, 2012 6:01 pm
Today, I got my SS808. The STOCK firmware lets me switch to 1080p... and my TV also shows that it is 1080p.
dero
Postby deadhp1 » Wed Nov 28, 2012 6:09 pm
The firmware is rooted and contains SuperSU.
Dero wrote:Today, I got my SS808. The STOCK firmware lets me switch to 1080p... and my TV also shows that it is 1080p.
dero
Can you install this app and tell us the output?
https://play.google.com/store/apps/deta ... screeninfo
Also what's the build # and kernel info that came on your device?
Dero
Postby Dero » Wed Nov 28, 2012 6:38 pm
screeninfo shows w=1280px to h=672px, ending above the navbar. So, it's just scaled up...
model: MK808
andorid: 4.1.1
kernel 3.08+ SMP PREEMPT Fri Oct 26 08:59:55 CST 2012
build mk808_300j1_27-10-2012
Btw. I just read an announcment, that there is a new firmware for MK808 with stock 1080p support: http://blog.geekbuying.com/index.php/2012/11/28/mk808-1080p-firmware-release/.
dero
Dero
Postby Dero » Wed Nov 28, 2012 7:03 pm
Hm, I just flashed the firmware from the blog, but it's still showing Oct 26 version, instead of Nov 25, as written at the blog.
I did copy the update.img to the SD-card and inserted. The device asked me to confirm updating and it did something. But, nothing has changed?
llewelld
Postby llewelld » Wed Nov 28, 2012 7:17 pm
Hi Deadhp1,
Geekbuying has posted a link to a 1080p rom.. is this just the same ROM with your kernel?
Postby deadhp1 » Wed Nov 28, 2012 7:43 pm
dero
Same firmware. It's good that they posted it up!
Matty2013
Postby Matty2013 » Thu Nov 29, 2012 2:23 am
I'll be getting my MK808 in a few days so I'll be itchin' to learn all this. I've never owned anything android so it's all new to me.
Does this firmware replace the finless 1.5 or is this an update and the finless is sort of just an interface update?
T68
Re: Sv: 1080p Firmwares!
Postby T68 » Thu Nov 29, 2012 4:44 am
Hi!
Will the new 1080-firmware work well on a 720 TV?
Skickat från min HTC Desire via Tapatalk 2
Dero
Postby Dero » Thu Nov 29, 2012 4:49 am
deadhp1,
does this mean they posted a firmware where they replaced the kernel with YOUR build? Or am I mixing quotes up?
And: hence the firmware is build with "leaked" kernel source, hence might be incomplete...
dero
balanadi
Postby balanadi » Thu Nov 29, 2012 8:44 am
I would like to tell you guys that i test it yesterday almost for 8 hours the new firmware released on
http://blog.geekbuying.com/index.php/20 ... e-release/
And everything seams to work smooth, it is a real 1080p ( i tested on Samsung Smart D8000 46inch) , the wifi is almost stable , the ethernet working very smooth , i was watching online for few hours hd movies , and the heat is just a little more than the original firmware.
My only dissapointment is that that i can not use Sopcast on this 4.1.1 JB , so i hope someone will release a kernel for ICS 4.0.4 or even better , a mk808 - ICS-1080p - firmware - release very soon.
Shifty-PK
Postby Shifty-PK » Thu Nov 29, 2012 9:20 am
balanadi wrote:I would like to tell you guys that i test it yesterday almost for 8 hours the new firmware released on
Sounds great, did you noticed any interface lag? For example the mouse movement not going as smooth as it should?
Dero
Postby Dero » Thu Nov 29, 2012 9:27 am
I am also having the FW since this morning on the device. It's true 1080p as shown by screeninfo.
At first, the interface was lagging a bit, but with scaling to 1416 MHz it looks really good!
However, I can't get dynamic frequency scaling to work correctly...
Antutu scores: with perf@1416 @1920x1032 (1080p)
total 7571
CPU 3179
GPU 2119
RAM 1519
I/O 754
dero
BTW. the kernel was built by "xbmc@ubuntu"...
balanadi
Postby balanadi » Thu Nov 29, 2012 12:01 pm
I noticed a little bug with the mouse movement , and also i tested the kernel_mk808_test6_1416mhz.img on the mk808_rooted_ICS_update and it was working on a full 1080p , few bugs , and when i play the mkv movies or online hd movies there is a big delay between the video and sound. ... i will test later tonight finless1.5a rom with the new 1080p kernel and i will post a review...
