android 4.2.
rainlake
android 4.2.
Postby rainlake » Wed Nov 14, 2012 10:10 am
more problems than I can image.
so, only a screen capture here.
Popeye
Re: android 4.2.
Postby Popeye » Wed Nov 14, 2012 10:21 am
Impressive! Looking forward for a working rom :D
kmunir
Re: android 4.2.
Postby kmunir » Wed Nov 14, 2012 10:42 am
Wow rainlake, you are going too fast here :) keep up the great work you are doing for this community :D
alwaysbless
Re: android 4.2.
Postby alwaysbless » Wed Nov 14, 2012 11:34 am
this is still going to use the same mk808 kernel as the other images?
rainlake
Re: android 4.2.
Postby rainlake » Wed Nov 14, 2012 11:39 am
alwaysbless wrote:this is still going to use the same mk808 kernel as the other images?
yes. I did not try to compile a kernel.
maybe I should try it.
antieco
Re: android 4.2.
Postby antieco » Thu Nov 15, 2012 12:36 pm
Whats the clock speed of your device? mine wont go further than 1008GHZ... but it shows 1608GHZ avaiable. Ive checked with different kernels and changing the governor but couldnt get any change.
