10.26 jb firmware, big issue.
rainlake
Postby rainlake » Sat Oct 27, 2012 12:24 am
I dont know what are they doing. as Bob metioned:
WARNING! If you read nothing else READ THIS!
On this kernel the reboot APP is causing Cache or file system corruption! This is not the reboot APPS fault. This is intermittent. Sometimes it works OK sometimes not.
The kernel is NOT properly processing the reboot command and is corrupting file systems!
SO DO NOT USE REBOOT from the reboot APP! YOU HAVE BEEN WARNED!
All other functions seem to be OK except reboot.
In fact the unit WILL power off believe it or not using the power off command!
If you use reboot and are stuck on the boot screen or boot logo, you will have to reflash the ROM.
We will work on seeing if we can fix that later but I believe it is a kernel problem.
The other kernels do not have this problem.
if you push anything to /system, you have a high possiblity crash your device. you have to reflash it.
szantinge
Re: 10.26 jb firmware, big issue.
Postby szantinge » Sat Oct 27, 2012 2:33 am
Hey Rainlake,
Good to pay attention to this problem.
So is this a kernel issue or is this the firmware? If it is the kernel would it be better to flash an olser kernel with the new finless bob rom or the stock rom. If it is the firmware it obviously isnt.
