unable to get into flash mode
Postby OxyJin » Sun Jun 16, 2013 11:57 pm
Hi eveyone, I am unable to get into flash mode to install firmwares. I brought the MK808 from geekbuying via Amazon. I did follow the instruction for Rockchip Batch Tool found on this forum "Flashing the Firmware" by deadhp1, but did not work for me.
After I check the "Connect to PC" option in MK808, MK808 shows up in device manager under Portable Devices. when I load up the flashing tool, the device is not found. I can not install driver as well. When I try i get a message that said the driver is up to date.
I try the pin method. Pushing the pin brings up brings up the volume control. Holing it over 10 seconds does nothing and the volume control stayed on the screen. The pin behaved like a hardware volume up bottom.
Android version 4.2.2.
Kernel version 3.0.36.
Build number mk808-303j2
Re: unable to get into flash mode
Postby lewy20041 » Tue Jun 18, 2013 7:23 am
push the pin before turning on device.
Everything is possible if we work together!
Users browsing this forum: No registered users and 3 guests
