XTV Firmware V1.3 (07.03.2013)
ACoster
Re: MK808/MK808B XTV Firmware V1.2 (05.03.2013)
Postby ACoster » Wed Mar 06, 2013 4:36 am
Is the new release also for the MK808B or you have a seperate ROM for it ?
I thought I needed to download a different ROM for the B-version...
muratremix
Postby muratremix » Thu Mar 07, 2013 1:24 am
Which kernel do you use in this rom? 2dark4u 1.4 or?
Postby lewy20041 » Thu Mar 07, 2013 2:30 am
muratremix wrote:Which kernel do you use in this rom? 2dark4u 1.4 or?
kizs v4
Postby lewy20041 » Thu Mar 07, 2013 2:31 am
ACoster wrote:Is the new release also for the MK808B or you have a seperate ROM for it ?
mk808b ver. have its own tread
muratremix
Postby muratremix » Thu Mar 07, 2013 5:22 am
I just put this fw on MK808. However, moborobo method is painful. Without extra installs, there is no launcher and not much thing you can do.
Suprisingly wireless works better than Hybryd FW 2.1.2.
I made a video playback test with this fw, it is just a draft, no voice over etc.
Captured full screen 1080p so you can actually see how it looks on TV.
http://www.youtube.com/watch?v=SJxfmPRE2eA
Watch in HD or 1080P
Postby lewy20041 » Thu Mar 07, 2013 6:00 am
yap. the wi-fi is better becouse its based on newer ver of my hfw that i i didnt published yet.
moborobo is painful but thats the only way to put this futures.
muratremix
Postby muratremix » Thu Mar 07, 2013 7:51 am
lewy20041 wrote:yap. the wi-fi is better becouse its based on newer ver of my hfw that i i didnt published yet.
Isn't there a way to backup all flash (nand flash backup) and make an image from this?
That way you can preinstall rom, install everything, make a backup, and everybody else can restore this backup / flash / one big .img file via flasher?
Postby lewy20041 » Thu Mar 07, 2013 8:13 am
i will think about it but for now im doing it this way;)
bovoro
Postby bovoro » Thu Mar 07, 2013 9:24 am
Hi, i have little troubles with this firmware and XBMC freeze all system , i need to plug off energy in some games too crashes angry birds space, anyone have this issues?
alexz75
Re: XTV Firmware V1.3 (07.03.2013)
Postby alexz75 » Thu Mar 07, 2013 12:43 pm
I here any download links?
dheerajjotwani
Postby dheerajjotwani » Thu Mar 07, 2013 12:48 pm
Any chance of being able to use usb wifi Dongle. Rtl8192cu
tapped on Note II cdma
Postby lewy20041 » Thu Mar 07, 2013 1:08 pm
no proplem;)
wait for next ver.
maybe today...
edit:
isnt it build in by default?
lukesan
Postby lukesan » Thu Mar 07, 2013 4:38 pm
Damn, just made the time to install this one ..... uploading 1.3
Lewy would it be possible to check if it is possible to integrate the Ralink RT5370 driver, or which good wifi stick do you recommend?
Postby lewy20041 » Thu Mar 07, 2013 5:28 pm
ok i will add it if you post back how its work;p
if it will not work out of the box you will need to do this:
turn off wifi
-rename rkwifi.ko to other name
-rename rt5370sta.ko to rkwifi.ko (set aproperiet permisions)
-plug your usb wifi to mk808
- turn on wifi
lukesan
Postby lukesan » Thu Mar 07, 2013 5:51 pm
lewy20041 wrote:ok i will add it if you post back how its work;p
turn off wifi
- turn on wifi
Ouch, wife home = playtime over :D
Saturday morning seems like the next free playtime again.
Just found something on the freaktab forum, nothing about your rom but this is what I might be having with the 2.12 and streaming from my dreambox with that libstagefright.
'I did some testing. mp4 and mkv work well with libstagefright. AVI containters on the other hand are all scrammbled. Turn libstagefright off and they are descrambled. '
So lets test that with this rom
DawdlingPanic
Postby DawdlingPanic » Thu Mar 07, 2013 10:54 pm
I love the work you've been doing, (I've been extremely happy since v1). I have a problem with v1.3 though. Moborobo can't find my device now, it did in version 1.2. I don't know what is wrong!! i followed all your instructions, I turn usb debugging on, I just literally tried everything (been trying for 2 hours now :p). Do you think the Moborobo update has something to so with it? Also, why did you change the spoof and the launcher from openlauncher to tvlauncher? Thank you again for the great work!
I went back to v1.2 and here is what the problem is. For some reason, with firmware 1.3 flashed, my computer doesn't recognize it as a usb device it doesn't even think a device in plunged up, therefore moborobo won't work ( i tried on 3 computers). So there must being something wrong here...... because when i flash v1.2, the computer shows an device.
bovoro
Postby bovoro » Fri Mar 08, 2013 12:01 am
hi, i have the same issue, no detect, and in storage in te top right corner has three dot... option MTP , massive storage and camera mode, i try to activate anything and crash to home.
Postby lewy20041 » Fri Mar 08, 2013 1:28 am
did you traied to check conect to pc and open ACI by lewy20041.exe
did it install?
anyway i will look into this.
there wasnt much interest in open launcher and people were
complaining, thats way i changed conception.
i will publish gtv apps pack so anyone
could use them .
edit:
found the problem, its kernel related. if you can, flash just this kernel http://d-h.st/TiC with finless tool
will fix this today and reupload new package.
edit2:
first post updated.
alexz75
Postby alexz75 » Fri Mar 08, 2013 5:24 am
Not able to enable wifi on my 808B
Postby lewy20041 » Fri Mar 08, 2013 6:02 am
alexz75 wrote:Not able to enable wifi on my 808B
mk808b ver have its own tread
viewtopic.php?f=111&t=1679
