1080p Firmwares!
Stock and Custom Firmware Development For the UG802.
1080p Firmwares!
Postby deadhp1 » Mon Nov 26, 2012 5:23 pm
Thanks to all the great info and hard work done by everyone in the MK808 development section I was able to build a 1080p kernel for the UG802.
Basically from what I can tell everything is working.
Wifi works, video acceleration works.
It has a resolution of 1920x1032 for the user interface. This will not change even if you switch resolutions for your tv(it will scale to fit on 720p tv or whatever else.)
I also built a version for the MK808 which is faster I believe due to the heatsink.(antutu of over 8000)
First run of Antutu benchmark on the UG802 was 6211, second run after cooling down was 6740.
Cpu won't go higher than 1200Mhz. It really shouldn't because it will overheat with no heatsink.
Some teaser shots:
Download "1080p_UG802_JB_Preview.zip" from ultramegabit
http://ultramegabit.com/file/details/ipCzb6bmr7o
OR
Download "1080p_UG802_JB_Preview.zip" from the Google Drive mirror
http://adf.ly/EY7KP
(UG802 Firmware--->1080p_test--->1080p_UG802_JB_Preview.zip)
Runner68
Re: 1080p Firmwares!
Postby Runner68 » Mon Nov 26, 2012 11:51 pm
Thank a lot, I will try it tonite. :)
bayard0
Postby bayard0 » Wed Nov 28, 2012 12:54 am
nice work,
is there a way to change the DPI?
jerrylee
Postby jerrylee » Wed Nov 28, 2012 2:44 pm
Thanks a lot for your great work again!! :lol:
Deivs
Postby Deivs » Sat Mar 02, 2013 9:01 am
Thank You, work very well, use it more than 3 weeks.
