UG802 JB Preview Firmware
Stock and Custom Firmware Development For the UG802.
Postby deadhp1 » Sat Nov 03, 2012 3:52 pm
11/03/2012
We are supposed to be getting the official JB firmware for the UG802 at some point tonight/tomorrow.
I had started this project before I found that out.
I first tried to take the MK802 III system and make a system.img, but I just couldn't get it to work. None of the permission are set correctly.
I then tried using the MX1 system.img and managed to get that to work after replacing the wifi modules. That system.img is not very good specifically netflix and keyboard.
So what I have done is taken the boot.img(with kernel) and wifi modules from the MK802 III.
I then took the system.img from my rooted MK808 beta 2 release and replaced the wifi modules with those above.
So what we have is a working rooted JB update for the UG802.
I'm calling this a preview because we'll be getting the official very soon. So this is only for those that can't wait.
As a plus it seems to have very good audio sync.
Download ug802_JB_preview_update.zip below:
http://ultramegabit.com/file/details/W-TMQhp8XH0
Mirror provided by userx:
http://www.ex.ua/view_storage/942774259228
userx
Re: UG802 JB Preview Firmware
Postby userx » Sat Nov 03, 2012 7:04 pm
Thanks... testing now
userx
Postby userx » Sat Nov 03, 2012 7:26 pm
WOW... this is it guys. Perfect sync finally. :D :) :D
System UI is a bit smoother/snappy. Not a hugh improvement but a little more responsive.
Videos play in perfect sync in all formats. This is what we have been waiting for.
Colors seem a bit more punchy or richer, cleaner. Not perfect but a small improvement was clearly made.
The old Rom was a bit dark and muddy.
1080p Mkv's plays but just ok. I noticed consistent frame drops... not so good.
But watchable and at least it's in sync.
Wifi connects no problem. Does not drop out/off.
The screen is NOT stretched. They got that right.
This is a hugh step in the right direction.
AND we got the right click, back button back.... :mrgreen:
Also looks like the cpu is running at 1.6 max... antutu score 6120
The best ROM to date for the UG802.
I used Rockchip_Batch_Tool_v1.5 to update to this ROM.
Not sure if SD card method works, I didn't test that method.
Thanks deadhp1 you the man! :D
userx
Postby userx » Sat Nov 03, 2012 8:06 pm
OK... good news
I got the old stock browser to work with an old Flash Player.
I'm using Flash version 11.1.115.11
But all the other current web browsers did not support Flash Player with Jelly Bean 4.1.
Dolphin Browser, Chrome Browser, Firefox Browser... NADA
EDIT.... use old version Dolphin Browser HD 8.5.1 and Flash version 11.1.115.11
Works with flash and jelly bean.
pana800
Postby pana800 » Sat Nov 03, 2012 9:58 pm
Upgrade the firmware with rockchip tool.
Don't know why but the flash works automatically in the stock browser. Wifi is ok.
Default video out is only HD ready 720 not Full HD. Can choose full HD option but it seems just the zoom option not native 1080.
Daved
Postby Daved » Sun Nov 04, 2012 1:41 am
pana800 wrote:Upgrade the firmware with rockchip tool.
Stock UG802 firmware doesn't have a real 1080p output either, it's stil 720p when set at 1080p.
gds
Postby gds » Sun Nov 04, 2012 7:14 am
Thanks deadhp1 I've been waiting for this
This is really awesome !
n3wb13
Postby n3wb13 » Tue Nov 06, 2012 1:56 am
I couldn't download the firmware any more. If you can please mirror it on sites such as Google Drive, MediaFire (no waiting with resume support), ZippyShare (no waiting without resume support) or maybe RapidShare. Thanks a bunch :D
userx
Postby userx » Tue Nov 06, 2012 6:43 am
I loaded your file to a free file host since you lost your file hosting.
Hope you don't mind. If you do, just pull the link or this post.
If you want to use the link at the beginning of your post, fine by me.
Here is the zip file hosted on a russian host site. Fast download.
UG802 JB Preview Firmware by deadhp1
DOWN LOAD LINK ug802_JB_preview_update.zip
Unzip file and flash with Rockchip Batch Tool.
Use Rockchip_Batch_Tool_v1.5 to Flash this ROM.
SD card easy update.img was not tested by me for this ROM.
So I can't confirm that method will work.
Ask deadhp1 if this update.img file supports the easy update SD card method.
Fordee
Postby Fordee » Tue Nov 06, 2012 6:54 pm
As my UG802's power/usb has snapped off, I think the SDcard update method is the only one available to me..
Am I correct that I wont be able to flash the new kernel with everything else via SD..
... and could anyone take a real close picture of were the traces go, so I might be able to do a quick repair?
Thankx
bravomail
Postby bravomail » Thu Nov 08, 2012 10:33 am
This is very good JB firmware! I flashed it with batch tool and everything went good. All A/V sync issues gone, my custom streaming apps work etc! It's a keeper! Thank you, deadhp1! :D
silpot
Postby silpot » Sat Nov 10, 2012 9:37 am
I tried this JB Preview Firmware to my UG802 and I was surprised! It's far from the original firmware had my UG802.
Congratulations deadhp1! you have done a great job!
The only small problem is the 720p and 1080p mkv files playback. Drops some frames all the time during the movie playback.
I tested playing a few mkv files from external SD, from my network NAS via WiFi (54Mbps) and from a USB to Ethernet adapter.
In all cases the frame drop is visible. I dont know if this is because of the speed limit by kernel to 1.2 GHz instead of the maximum 1.6 GHz that could go the UG802.
I couldn't overclock the CPU to 1.6 GHz. The speed as I said before is limited by the kernel to 1.2 GHz.
It is possible to change only the kernel and unlock the speed limit so I can get my UG802 CPU to 1.6 GHz ?
mightyfes
Postby mightyfes » Sat Nov 10, 2012 11:03 pm
I was having a few issues with the 1.6 finless rom which initially worked great, I'm going to give this one a go now.
Thank you for your hard work
PS: this might be a silly question, can I still use the guide from the thread "Flashing the Firmware" for this one? I'll be updating from finless 1.6 JB
gamesfrager
Postby gamesfrager » Sun Nov 18, 2012 7:16 pm
Finally got to flash this rom. You do notice the performance of JB. Here are my findings:
Good:
- performance when swiping between home screens much better
- english dictionary is fixed. Before, almost all words had red underline
- i like the volume controls on status bar
- no crappy default launcher
- wifi bars at 3/4 seems better
Not so good:
- audio and video sync issue remains. Here is a video stream example
http://www.dw.de/%D8%A7%D9%84%D8%A8%D8% ... B1/s-30738
- too much screen flicker when there is a dialog box eg. Clicking a drop-down menu on a websie brings the selection box on screen, but too much flicker. Same flicker playing angry birds
Keep up the great work, looking forward for the next rom
Postby deadhp1 » Sun Nov 18, 2012 10:05 pm
I have a several UG802's. I've noticed that 2 of them produce a screen flicker and artifacting. These also produce the same thing on the ICS roms.
I can't make my other 3 UG802's do this. I thinks it's a build quality issue.
As for the audio/video sync I find it nearly perfect for mkv's and other videos.
I haven't gotten a chance to test internet streaming, but mine were streamed over local network.
I'll give that video a shot a bit later.
eCCoMaNia
Postby eCCoMaNia » Mon Nov 19, 2012 1:06 am
A/v sync problem starts after one hour of normal operation and if i restart device it works perfect for another hour.... :evil:
gamesfrager
Postby gamesfrager » Mon Nov 19, 2012 3:46 am
eCCoMaNia wrote:A/v sync problem starts after one hour of normal operation and if i restart device it works perfect for another hour.... :evil:
I confirm. Restarting the device solved the A/V sync. Could it be a process eating up memory?
eCCoMaNia
Postby eCCoMaNia » Mon Nov 19, 2012 4:29 am
or maybe the device heats up more than it can handle and something not work right ?
