mk808b wifi (bcm40183)
leolas
Re: mk808b wifi (bcm40183)
Postby leolas » Thu Apr 11, 2013 7:33 am
jps wrote:Puff.. i dont know then. Maybe a micro small chip with a micro small letters??? :S
:cry: maybe, i will follow searching.,
jps
Postby jps » Thu Apr 11, 2013 10:11 am
Queria decir de mirar con una lupa :P, mi chip PMU WM8326, es como una moneda de 1centimo, un pelin mas pequeño.
I wanna mean, to search with a ... "big cristal" (i dont know the traducction). My PMU WM8326 is like a 1 cte of euro, a bit more small. (Sry my english)
leolas
Postby leolas » Thu Apr 11, 2013 11:55 am
I assure you that is not a chip with that size in my mk808b jajaja, apart od nand,ram and proccesor. Fixed regulator maybe? More things to test jajaja
Te aseguro q no hay nada de ese tamaño en mi stick jajaja aparte de la nad, ram y el procesador. Quizas un regulador fijo?. Mas cosas que probar jajaja
jps
Postby jps » Thu Apr 11, 2013 1:31 pm
Maybe a PMU integrated on another chip?... i have no more ideas
jps
Postby jps » Fri Apr 12, 2013 7:56 pm
Esto me aparece con la wifi detectada. This appears to me with the wifi detected.
root@minix:~/# rfkill list
0: rk903_26M: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
leolas
Postby leolas » Wed Apr 24, 2013 5:58 am
No advances, fixed regulator didn't work, out of ideas for now. Any advances in your side omegamoon?
t3l3m4k0
Postby t3l3m4k0 » Wed Apr 24, 2013 3:18 pm
leolas wrote:I assure you that is not a chip with that size in my mk808b jajaja, apart od nand,ram and proccesor. Fixed regulator maybe? More things to test jajaja
you are rigtht MK808, MK808B don't have PMU chip, but maybe there is one GPIO pin to enable Bluetooth/Wlan.
leolas
Postby leolas » Wed Apr 24, 2013 6:55 pm
Then it will be hard to find it.
mawkish
Postby mawkish » Sun Aug 11, 2013 4:20 am
Hello all, recently I bought a MK808B but it turns out that the wifi driver is not working on picuntu, so I decided to debug it and find out the problem.
I think I have some findings on the problem and wanna see if someone is still fixing it.
As many of you suggested that the wl_reg_on pin is somehow remapped to another pin, I have tried some weird testing hoping to find out the pin from Finless 2.1 ROM by hard-coding a gpio testing module using the debugfs.
It appears that the wl_reg_on pin(D0 I suppose) may not be remapped as I find that it is already requested (barely means a name is marked on the pin desc) by someone ( I believe it is the sdmmc kernel that does this) and the whole GPIO3_PC[0-7] pins are requested, unless the kernel programmer forgot to clear the request calls :roll:
Here is what I find about GPIO3_P[ C and D ]: where X is requested, 1/0 is current pin value
Code: Select all
X,X,X,X,X,X,X,X,X,X,1,1,1,1,1,1
so PC[0-7], PD0 PD1 are all requested. (Don't readlly sure about the pin value is correct or not, but I think the request state is more relevant as you move on to the story below)
As I have no kernel development experience and minimal C skills, I don't dig into the gpio_request function and don't try to see the current gpio value behind it, as I believe the existing turn-on logic should work.
But then I observed an interesting phenomenon when I try to do the same testing on other pins.
I try to request all pins values and their request state, after I did so, the wifi module stops working. (Hopefully the stick was not burnt out as I understand messing with the gpio can causes severe problem)
Then I pin down which pin causes that problem by requesting it one by one, it appears that when I request GPIO0_D[6](just do a gpio_request), the system loses the spi connection with the module.
I find on RK3066_datasheet_brief.pdf this pin has an alternative function of PWM2..
Oops... and then I hesitate to dig in further as I will probably burn the RK903 chip easily in case it is truly used as a pwm pin to drive an external circuit to power the RK903.
So forgive me, I truly don't want to break the case of my android stick and investigate the circuit. :|
I hope that someone can continue to work on it in case my infomation is relevant
Thanks everyone :mrgreen:
mawkish
Postby mawkish » Sun Aug 11, 2013 12:20 pm
Good news
Finally I got the bcm40181.ko passes the famous timeout error
The rk903 module can now be identitied by as the sdio-card just like the stock firmware
I will post the changes tomorrow when I get back home from work
It seems the chip is either driving the pwm as a clock / driving an additional power circuit for the wifi module
tonikasch
Contact:
Postby tonikasch » Mon Aug 26, 2013 4:48 pm
And the long awaited kernel patch...
http://www.freaktab.com/showthread.php? ... for-MK808B
Thanks for the idea, mawkish ;)
MK808 as server, waiting for full Mali-400 support
Minix X7 arriving home mid September to bring it full linux support :)
...Itaca te ha dado el bello viaje. Sin ella, nunca habrías salido...
fkpwolf
Postby fkpwolf » Mon Sep 16, 2013 10:32 am
I used the patch and it works! but I found an issue when add bcm40181 in /etc/modules, dmesg report error:
bcm40181: section 2 reloc 10 sym 'printk': relocation 28 out of range.
If I login in console, type "modprobe bcm40181", it works.
Return to “Development”
