mk808b wont't boot, stops at "android"
New MK808 with internal Bluetooth!
Postby sim1 » Fri Apr 12, 2013 2:28 pm
how do i fix this?
i tried to flash the rom, but the pc didnt recognize the device. it might be the cable, since i dont have a usb extension i used the regular usb "power" cable. can this be the problem?
are there an alternative way to fix this, it will suck hard to loose all my settings and stuff:)
sorry about my bad spelling, i only had the mk808b for 10 days and i was starting to really enjoy it. so im really pissed off....
Re: mk808b wont't boot, stops at "android"
Postby tabletuser33 » Tue Apr 16, 2013 7:31 am
Cable is standard USB mini, so any will work. Don't use extension cables or HUBS for updating. Every firmware update I've done I've lost all settings and apps. I use Titanium Back to save apps and system data, read carbonite works well and for just backing up apps; ES File Explorer works great. You have to get the drivers loaded correctly under Windows for flash to work.
I took added my info to updating firmware ... om-17.html
Return to “MK808B”
