mk808b + usb ethernet adapter
New MK808 with internal Bluetooth!
sti.que.c.pas.facile
Postby sti.que.c.pas.facile » Fri Feb 08, 2013 9:33 pm
Hi all. After trying for 3 days to make my ehternet adapter to work without success, i' m wondering if someone managed to use a mcs7832 equiped usb ethernet adapter?
After loading the correct driver(mcs7830.ko) my system enable the device but i cant connect to the network. I check on my ubuntu pc and it uses mcs7830 driver AND usbnet module.
Is usbnet included in any mk808b rom?
Btw im running finless 1.6 right now but i can try a different rom if that helps
Re: mk808b + usb ethernet adapter
Postby sti.que.c.pas.facile » Mon Feb 11, 2013 9:48 pm
Well, after a few hours of reading ive found out that there is many version of this mcs7830.c file (driver) the official one fron asix.com.tw is 8yrs old (2005) i've found a newer one (2010) that need to be compile.
Can someone show me the way to build a android envir. So i can build stuff by myself. What do i need? I'm on ubuntu 12.10 and everything i see is about 12.04 or earlier...
Here is the link to the latest c file i need to compile
https://docs.google.com/viewer?a=v&pid=explorer&srcid=0B5BbKwRj8UvHV3NHczdtOFhteTg
mustafaupk
Postby mustafaupk » Sat Mar 23, 2013 12:19 am
I'm having similar issues as you so I am very interested in if you were able to solve your problem. I have a DLink E100 usb-ethernet adapter which uses the asix.ko and usbnet.ko modules to work on my Ubuntu laptop. I am unable to get it detected on my MK808 (finless 1.7). So I would also like to know how I can compile the asix and usbnet drivers for my mk808.
Postby sti.que.c.pas.facile » Sat Mar 23, 2013 7:56 am
I ended up buying another adapter.
The htc usb hub with rj45 port. Its a little bit exoensive but it worth the money. You can buy frim ebay for ariuns 35$ or if you trust taobao's agent you can find it around 15$
Envoyé depuis mon CJ ThL avec Tapatalk
Return to “MK808B”
