Firmware 4.1.1+1080p
jlcd
Postby jlcd » Thu Nov 29, 2012 6:16 am
4.1.1+1080p firmware for NEO X5 available here: http://www.sendspace.com/file/cisp01
you may download it first and wait for our instruction about how to flash it! DON'T do it without our tutorial.
http://www.facebook.com/minixtech
alwaysbless
Re: Firmware 4.1.1+1080p
Postby alwaysbless » Thu Nov 29, 2012 10:32 am
Does this fw address:
Bluetooth LAN/Mac addy change
Power button shuts unit down but blue light remains on
Wifi limited to 65mbp
No hw decoding in certain video player apps
jlcd
Postby jlcd » Thu Nov 29, 2012 4:58 pm
MiniX NEO X5 firmware updates and instructions
For updates, all personal data and apps will be deleted from the internal memory. Therefore, back up all important data. After the update again, all settings again. As always, everything at your own risk. For any damage not accept responsibility
1.- Firmware Download and unzip
2.- Turns the X5 and closes the unattached USB cable to the OTG port or PC to
3.- On the X5 on the back there is a small button called "RECOVER". This button, press down gently by paper clip, you can feel a distinct resistance
4.- Switch on while holding the RECOVER button to release X5 and after about 5 to 7 seconds
5.- Windows will now try to install the driver, but it will fail. In the Device Manager is where you will be shown an unknown device. Then installs the appropriate drivers from the "Driver" folder manually (depending on which operating system or 32/64 bit version)
6.- Now Opens RKBatchTool. It should now appear below a pink or green button. If it is pink, you have to perform steps 2-4 again
7.-If the dot is green, the tool has detected the X5. Goes above the upper right on the button with the three dots and select the appropriate. Img file from the firmware folder from
8.- Then you press down the button restore. The upgrade is now done. At the end of a message is that the upgrade was successful / successful
9.- The X5 should then launch in a new, what will take a while. Stop in time in any case the power supply! Done!
2012-11-29 (BETA) Update Android 4.0.4 -> 4.1.1 Android
From Minix-forums. de
tibox
Postby tibox » Fri Nov 30, 2012 4:21 am
Thanks !
